Author Topic: Top vent query  (Read 1702 times)
Offline Duke
Top vent query
« on: October 08, 2013, 07:06:19 pm »
Hi chaps,
The top vent in my GTI, above where the nav unit is always creaks when driving, most likely due to the cold/warm air coming through the vent under it. I have taken it apart previously a few times and put padding around the insides to try and stop it but its not made any difference.
I've noticed some (non-GTI?) have a storage tray on top instead of the vent.. do they have the same problem? Does anyone have the part number?
Offline skard
  • -Receive: 245
Re: Top vent query
« Reply #1 on: October 08, 2013, 07:11:33 pm »
Yes they do creak, and also look crap in co parison.
Pretty sure the top sensor is useful for the climatronic though if you are downgrading.
I put a brand new upper vent in this year and it creaks.
Offline doylebros
Re: Top vent query
« Reply #2 on: October 08, 2013, 07:15:38 pm »
I found that spraying the contact points with silicon spray,when reassembling solved that problem for me.
Offline Luka
Re: Top vent query
« Reply #3 on: October 08, 2013, 07:48:29 pm »
I fitted the tray and it's the best thing I've done recently! No creaks or noises, couldn't care less what it looks like, all about peaceful driving!
Sold - 2006 Tornado Red GTI 3dr
Offline Duke
Re: Top vent query
« Reply #4 on: October 08, 2013, 08:00:20 pm »
Thanks for the replies  :happy2: I'll give the spray a go first then think about changing it for the tray if it doesn't work.
Offline sootpig
Re: Top vent query
« Reply #5 on: October 09, 2013, 06:33:53 am »
sellotape foam tape does the trick   :happy2:
Offline Duke
Re: Top vent query
« Reply #6 on: October 14, 2013, 08:55:09 pm »
What does that bit do on the top, does anyone know? Is it taking cabin temp?
Offline doylebros
Re: Top vent query
« Reply #7 on: October 14, 2013, 09:12:53 pm »
If I remember correctly its known as "Sunlight Photosensor 2 G134"
Disconnecting it will throw up a fault up when scanned with VCDS - how it affects the air-con system I've never run it disconnected long enough to find out.
Offline alackofspeed
  • -Receive: 24
Re: Top vent query
« Reply #8 on: October 14, 2013, 09:18:33 pm »
The sensor gives the climate control an understanding of the radiant heat being felt in the car, in addition to the air temp, to work out what the resultant temperature felt by the car occupants isl. It's just like being outside in the sun or the shade - the air temp might be the same, but you're much warmer when benefiting from the radiant heat too.
Offline Duke
Re: Top vent query
« Reply #9 on: October 14, 2013, 09:26:46 pm »
Fantastic replies, thank you.
Offline f1fan
Re: Top vent query
« Reply #10 on: October 14, 2013, 10:16:30 pm »
My GTi car already had the tray when I bought it, it doesn't creak and I've removed it loads of times getting to the stereo.  I don't put anything in it as you see the reflection in the windscreen when driving.
I'm after the top vent and do the opposite swap to you!
Black 2008 GTi, InPro smoked door mirror indicators, genuine Autohaus Wolfsburg plate holders, uk legal pressed metal plates, LED number plate lights, MTEC super white headlights & side lights, LED internal lights, Polo stubby aerial, Kenwood DDX4023BT head unit & Enfig surround.
