November 16, 2024, 03:09:51 am
All Things Mk5
Mk5 General Area
At how many miles should you change the DV?
Topic: At how many miles should you change the DV? (Read 1990 times)
Homer
Always Involved
-Given: 12
-Receive: 4
October 08, 2013, 08:17:31 pm »
I did this around 30k to revision D, car has now done 80k and the boost doesn't feel as sharp, time to change again?
Nodz
Just look at my post count
-Given: 73
-Receive: 103
My Ride:
Re: At how many miles should you change the DV?
Reply #1 on:
October 08, 2013, 08:21:11 pm »
I've got a Rev G on and have it checked at very service to make sure all is ok. If it doesn't feel as sharp anymore might be worth a change
George118
Taking part
-Given: 3
-Receive: 2
Reply #2 on:
October 08, 2013, 09:12:37 pm »
Gave my car an oil service and new DV today, I thoroughly inspected the old rev C (I think it was C) and it looked fine but the car felt so much more alive with the new G.
Could just be all in my head though!
Homer
Always Involved
-Given: 12
-Receive: 4
Reply #3 on:
October 09, 2013, 12:09:51 am »
What made you guys go for the revG and not RevD?
Tortaruga
-Given: 36
-Receive: 105
Reply #4 on:
October 09, 2013, 12:36:58 am »
It forms a better seal as it utilises a rubber diaphragm. The D apparently leaks a little by design.
'07 Red manual
aarondsg
Always Involved
-Given: 16
-Receive: 3
Reply #5 on:
October 09, 2013, 02:42:08 am »
How do you check if it is Ok?
Also what is the best revision?
R-Tech Power Stage 2+ Edition 30 (LC9Z)
George118
Taking part
-Given: 3
-Receive: 2
Reply #6 on:
October 09, 2013, 04:58:06 pm »
I just went with what GSF had in stock as I didn't want to wait.
When you've taken it out you will see the rubber seal which connects to the piston/diaphragm if there's no rips/holes it should be good to go but if you've done 60k on it AND you've already got it out it would be rude no to replace it lol
aarondsg
Always Involved
-Given: 16
-Receive: 3
Reply #7 on:
October 10, 2013, 12:50:37 am »
What is the access like to get to it is it a long job?
Or a fiddly finger slashing little finger job lol
George118
Taking part
-Given: 3
-Receive: 2
Reply #8 on:
October 10, 2013, 07:27:07 am »
Really easy, it's a bit fiddly but manageable. I did it with a set of Allan keys and only one wheel jacked up and I'm by no means a mechanic! I always think if you can't get it off take it to a mechanic and if you can then just do again in reverse fitting the new part lol
good luck buddy
aarondsg
Always Involved
-Given: 16
-Receive: 3
Reply #9 on:
October 11, 2013, 09:27:59 am »
Ok thank you
Hopefully I can get in there with a small ratchet
Tbh I can't see it possibly being more difficult than my r26 Megane so should be Ok
Spadds
Always Involved
-Given: 11
-Receive: 2
Reply #10 on:
October 11, 2013, 02:57:49 pm »
Fit this and forget about DV worries!
http://www.psituning.com/product.php?xProd=22466
All Things Mk5
Mk5 General Area
