Author Topic: springs ???  (Read 1701 times)
Offline golfgti10
springs ???
« on: October 09, 2013, 08:37:25 pm »
help is needed I wish to get some lowering springs for my gti, im looking to get this wheels http://www.ebay.co.uk/itm/370837517606?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
and then some 225 40 18 Goodyear Eagle F1 Asymmetric 2 for them
I want some lowering springs to sit the arches just above the tyres can anyone help
  • -Receive: 427
Re: springs ???
« Reply #1 on: October 09, 2013, 08:43:45 pm »
Wheels are tyres will be fine.
Width and ET on those wheels are good for your car. Will give you 13mm poke over standard 7.5 ET51 so fill fill the arche nicely and give you a nice stance. Springs are springs, you may get a wee bit of rubbing at the front, nothing the screw delete mod under the front won't cure.
Look into H&R springs, cost less than £200 so not expensive.
Offline golfgti10
Re: springs ???
« Reply #2 on: October 09, 2013, 09:07:26 pm »
don't fancy any rubbing, how low would you suggest
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: springs ???
« Reply #3 on: October 09, 2013, 09:25:57 pm »
Unlikely you will rub just on springs. Eibach sportline or H&Rs are your best bet
Offline golfgti10
Re: springs ???
« Reply #4 on: October 09, 2013, 09:30:03 pm »
how low??
  • -Receive: 427
Re: springs ???
« Reply #5 on: October 09, 2013, 09:43:20 pm »
Eibach Sportline around 20mm and H&R a wee bit more.  Check out their respective sites.
Offline golfgti10
Re: springs ???
« Reply #6 on: October 09, 2013, 09:44:29 pm »
what would you suggest on how low to go
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: springs ???
« Reply #7 on: October 09, 2013, 09:47:15 pm »
H&Rs or coilovers
Offline golfgti10
Re: springs ???
« Reply #8 on: October 09, 2013, 09:49:35 pm »
no not what make how low would I have to to get near the tyres
Offline kahunajb
Re: springs ???
« Reply #9 on: October 09, 2013, 10:40:15 pm »
Coilover low. You will still have arch gap with springs.
05 Laser Blue Mk5 GTI - Revo Stage 1
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: springs ???
« Reply #10 on: October 10, 2013, 07:38:25 am »
You will still be an inch or more away from the tyre with springs only. You cant really decide how low to go on springs, they go however low they are designed to be. If you want to pick how low you go, then buy coilovers
  • -Receive: 427
Re: springs ???
« Reply #11 on: October 10, 2013, 09:18:44 am »
^^^^ This........next
Offline golfgti10
Re: springs ???
« Reply #12 on: October 10, 2013, 09:30:38 am »
So you two as I can see your cars in the bottom of the post are your cars lowered if so how much and with what springs???
  • -Receive: 427
Re: springs ???
« Reply #13 on: October 10, 2013, 11:02:02 am »
^^^^ you won't get an exact drop as they are springs, every case (within reason) will be different. Look on the manufactures websites, usually give you a distance BETWEEN which the springs will drop you car or will say UP TO said drop.
Chap I know on here had H&R's on his Eddy (albeit with spacers fitted to his wheels to clear his BBK) and it dropped the front end around 40mm so the edge of the tyre was exactly in line with the ach, looked the dingles and fine in a straight line, give it some spirited driving around a corner and rubbing occurred. Another chap ran the Eibach Pro's and got NOTHING at all, no drop.
Adjustable coilovers is your answer or H&R Springs.
Check out GNJ Motorsport's site for springs. Speak to Graeme, he's also a member on here.......
~~ Clicky here ~~
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: springs ???
« Reply #14 on: October 10, 2013, 11:33:30 am »
Im lowered on kw v1 coilovers. Rears as low as they go with no adjuster. Fronts are 1 turn off the lowest setting
