Author Topic: Air Con Compressor symptoms  (Read 2008 times)
Offline jakex181
« on: October 10, 2013, 11:37:49 am »
Ive been researching common problems for the 2.0 TFSI engine, i have seen this issue surrounding the air conditioning compressor. What are the sympstoms of this problem?
« Last Edit: October 10, 2013, 05:04:20 pm by jakex181 »
Offline adminkatana
Re: Air Con Compressor symptoms
« Reply #1 on: October 10, 2013, 08:28:35 pm »
Happened to me about a month ago.
Basically the Air Con just blows warm air. Doesn't get cold any more. Had it re-gassed and then VW confirmed that the compressor is dead. Was told the part is about £550, was quoted £800 odd to replace it. Going to wait until it gets warm again next year before doing it.
Offline aarondsg
« Reply #2 on: October 11, 2013, 09:46:10 am »
The clutch stops engaging the freewheel happened on my tsi  :sad1:
R-Tech Power Stage 2+ Edition 30 (LC9Z)
Offline jakex181
« Reply #3 on: October 11, 2013, 10:27:06 am »
Ok so no strange sounds or anything? I ask because I get a belt slip sound from the engine then ?
Offline doylebros
« Reply #4 on: October 11, 2013, 06:12:33 pm »
There's parts on this link which may help you as alternator pulleys can cause issues
http://www.mk5golfgti.co.uk/forum/index.php/topic,73597.0.html
Offline Ollie.
« Reply #5 on: October 14, 2013, 06:56:43 pm »
My aircon didn't work, so I had it re-gassed and it was fine they said it was holding pressure. Then after a couple of months it got worse now it doesn't work at all there's just a faint hissing noise when the aircon is turned on. Is it likely to be a compressor issue?
Offline doylebros
« Reply #6 on: October 14, 2013, 07:01:26 pm »
Have a read here it may help you decided what to do next.
http://www.mk5golfgti.co.uk/forum/index.php/topic,73602.0.html
Offline Ollie.
« Reply #7 on: October 14, 2013, 07:10:36 pm »
Cheers for that, It sounds very similar to mine. I think I'll look into getting a new switch and see how it goes from there. :)
Offline doylebros
« Reply #8 on: October 14, 2013, 07:16:03 pm »
Don't forget to tell them you want the dye added, in case the gas leaks away again allowing a route for further testing!
Offline Ollie.
« Reply #9 on: October 14, 2013, 09:54:32 pm »
They put a dye in when I had it gassed earlier this year I'll get them to have a look when I get chance to take it in.
