Author Topic: speed sensor problem  (Read 6367 times)
Offline doylebros
Re: speed sensor problem
« Reply #15 on: October 12, 2013, 09:30:22 pm »
Offline bower
« Reply #16 on: October 12, 2013, 09:59:40 pm »
Why do I need to read that? Just a yes or no would have been more helpful
Offline doylebros
« Reply #17 on: October 12, 2013, 10:05:36 pm »
Not every car is the same - brake set up 1kd or 1kz or 1ky or 1ke
http://www.ebay.co.uk/itm/GENUINE-VW-VOLKSWAGEN-REAR-WHEEL-BEARING-AND-HUB-8V0598611-/380704023532?hash=item58a3ba63ec
As above - Even the dealer has hassle which bearing is fitted - but I'm sure it will fix it!
Offline bower
« Reply #18 on: October 12, 2013, 11:29:24 pm »
Cheers for your help I really do appricate it but what I'm trying to find out is where's the ring at????
Offline doylebros
« Reply #19 on: October 12, 2013, 11:39:09 pm »
It says on page 4
Sensor ring for ABS is
installed in wheel hub
look and compare yours
http://www.ebay.co.uk/itm/VW-GOLF-MK5-REAR-WHEEL-BEARING-AND-HUB-2004-2005-2006-2007-2008-2009-2010-/271055931830
« Last Edit: October 12, 2013, 11:48:26 pm by doylebros »
Offline vRSAlex
  • -Receive: 253
« Reply #20 on: October 13, 2013, 10:40:49 am »
Bit late now I've already stripped it lol. All I want to know is where is the ring? Is it the plastic bit?
The speed sensor is pointing at the ring  :happy2:
Follow AKS tuning on Facebook
Offline bower
« Reply #21 on: October 15, 2013, 06:42:03 pm »
well after replacing sensor, stripping the hub and cleaning it the lights have returned  :fighting: so just goin to replace wheel bearing and see if that cures it.
mot monday
Offline ChrisGti
« Reply #22 on: December 17, 2013, 05:50:01 pm »
Did the new bearing solve the problem? I've exactly the same thing going on currently.
Cheers,
Offline doylebros
« Reply #23 on: December 17, 2013, 05:57:29 pm »
Cheers,
Read what bower wrote here:-
http://www.mk5golfgti.co.uk/forum/index.php/topic,75004.15.html
Offline xjay1337
  • -Receive: 377
« Reply #24 on: December 17, 2013, 06:40:49 pm »
Cheers,
Use Vagcom or similar to actually diagnose the fault.
Check which side is having the problem.
Using the measuring blocks to measure LIVE the speed readings from the wheel.
Verify wiring integrity before replacing the sensor, resistance and voltage
If wiring is correct and sensor has been replaced and still having a problem then you can look at the speed sensor ring.
I had a terrible issue with my TDI which took ages to fix and in the end we were going to replace the ABS unit but the symptoms didn't add up and it turned out the problem was a faulty wire inside the body (all the battery etc needed to come out to rewire it, hitting a pot hole hard caused some damage)
