Author Topic: PCV Question  (Read 1083 times)
Offline RedED30
  • -Given: 19
PCV Question
« on: October 15, 2013, 07:21:58 pm »
Evening all.
I've used the search function, but no help.
PCV - Why do people remove it? is it just to minimise boost leaks?
Also remove/delete totally, or revamp as there is options for both.
Dan
Revo Stage2 - With Linear Throttle
Revo DSG
BCS Turboback Powervalve - This is a must.
ITG Closed Intake.. wooosh
Here to enjoy and help, with a hint of sarcasm, please do not be offended
Offline phem0r
Re: PCV Question
« Reply #1 on: October 15, 2013, 07:28:42 pm »
I replaced mine with the latest revision from vw, just before i got stage 1 remap as i had read it can cause boost leaks
Also a friends was on it's way out on his Seat, when sitting idle his engine kept revving up then dropping off, so i thought best to just replace it in case
MK5 Golf GTi - Revo Stage 1 - Forge TwinTake - Milltek Catback - Eibach Sportlines
Offline doylebros
Re: PCV Question
« Reply #2 on: October 15, 2013, 07:34:05 pm »
This is the common complaints as found by forum members
http://www.mk5golfgti.co.uk/forum/index.php/topic,44709.0.html
It should help answer your questions!
Offline Homer
Re: PCV Question
« Reply #3 on: October 19, 2013, 11:28:53 pm »
It's a cheap fix so get it done. I had mine done recently. It was causing the car to rev by itself and then drop off.
Offline Lewis86
Re: PCV Question
« Reply #4 on: November 19, 2013, 11:56:49 pm »
these also answer my questions lol
Offline Markyed30
Re: PCV Question
« Reply #5 on: November 20, 2013, 06:05:19 pm »
I felt after having my stage 1 for 6 months it just didn't pull as hard and thought I was just used to it l, A bhs revamp came up and I fitted it and felt like it pulled like it used to again that's my 2 bob  :signLOL:
