Author Topic: Is it hit and miss where the HU gateway is on 2005?  (Read 1192 times)
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« on: October 17, 2013, 03:45:04 pm »
I've heard it's in the wiper motor recess or up behind the steering wheel.  I'm a little annoyed with myself for checking when I had the wiper motor out, but alas, is it just hit and miss where it will be located on 2005 models? (55 plate)
Offline doylebros
Re: Is it hit and miss where the HU gateway is on 2005?
« Reply #1 on: October 17, 2013, 08:36:36 pm »
In front of the gear lever cubby hole is favorite for that year.
This is worth a read
http://www.mk5golfgti.co.uk/forum/index.php/topic,47405.msg589543.html#msg589543
« Last Edit: October 17, 2013, 09:29:20 pm by doylebros »
Offline mortygttdi
  • -Receive: 146
« Reply #2 on: October 18, 2013, 01:20:26 am »
55 plate it'll be above the clutch pedal unless its a dsg then it'll be above where the clutch pedal should be :happy2:
Offline foggy3061
« Reply #3 on: October 18, 2013, 06:57:11 am »
Exactly where the CAN gateway is on my 2005!
I found it quite a straight forward change once the lower dash panel (with the OBD2 connector in it) and air duct was removed.
2005 MK5 GTI 3dr Tornado Red, OEM+
Offline ripmateyy
« Reply #4 on: October 18, 2013, 10:38:07 am »
One of mine was above the clutch
The other golf I had it was buried up behind all of the fuse box and relays in the cockpit!
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #5 on: October 18, 2013, 10:44:33 am »
mine was also above the clutch pedal. Right pain in the ass to change!
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #6 on: October 18, 2013, 10:47:53 am »
Thanks for the help everyone, I'll check all the eas"ier" spots first :happy2: :happy2:
