Author Topic: loctite new wheel bearing bolt?  (Read 1069 times)
Offline bower
« on: October 19, 2013, 11:57:23 am »
should i put loctite on the new bolt? also should i use it in the brake caliper and carrier?
Re: loctite new wheel bearing bolt?
« Reply #1 on: October 19, 2013, 12:30:02 pm »
if your using the same bolts..it won't do it any harm to use it
Offline bower
« Reply #2 on: October 19, 2013, 12:35:17 pm »
im not using the same wheel bearing nut but i am reusing the ones for the brakes
« Reply #3 on: October 19, 2013, 12:40:09 pm »
the new bolt for the bearing is blue at the bottom which is thread lock--put a bit on the caliper bolts will be fine
Offline bower
« Reply #4 on: October 19, 2013, 12:44:27 pm »
cheers for reply  :happy2:
mines an aftermarket one so no blue bit, will put some on myself, cheers
