Author Topic: instrument cluster or ECU?  (Read 8326 times)
Offline GertTurdInside
Re: instrument cluster or ECU?
« Reply #15 on: November 02, 2013, 11:17:45 am »
It could be the cluster, but it could be a whole host of other items
where are you located?
Hi ed, I have contacted you via eBay as I see you sell can gateways pre programmed. I have also txt you but I'm now away and my signal is awful so my not pick up a reply. Can you contact me re. Supplying me a gateway please. Also someone suggested you may be able to advise me of where to look for the water ingress that has caused the gateway to fail.
