Author Topic: Mk5 GTI Instrument cluster swap  (Read 35904 times)
Offline Luka
Re: Mk5 GTI Instrument cluster swap
« Reply #30 on: December 21, 2013, 02:19:37 pm »
Hey there, i used vag k+ can commander. Full versions 1.4, 2.5 or 3.6 should work for you as long as you have the appropriate cable. Win XP is advised but Win 7 worked fine for me. Happy swapping.
 I bought this and it does not work in my car
http://www.ebay.co.uk/itm/USB-Interface-VAG-K-CAN-Commander-Full-1-4-OBD-OBDII-2-/150622636631?pt=UK_Diagnostic_Tools_Equipment&hash=item2311cf0a57
my car is golf 5 tsi 8/2007
my tacho 1K0920863A new tacho 1K0920873A
WHAT IS THE CORRECT SOFTWARE IN LOW PRICE to work in my car PROPERLY?
THANKS!!
That won't work on your car, only up to 2006. Only genuine works with your car, ££££.
Sold - 2006 Tornado Red GTI 3dr
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #31 on: December 21, 2013, 02:27:58 pm »
THANKS!!
cheap copy won't work with that
RSM on here is in Greece and can help you
Cluster and Key coding
Location Great Yarmouth
Offline sodmitris2
« Reply #32 on: December 21, 2013, 05:35:06 pm »
Thank you all for quick reply!
the 1.4 software not work in the car my choice read/write.
my cluster have chip MIRCONAS cdc 3797G C1 5622F
If you open a panel will look through two plaques
one has indicators kilometers and is empty
and another small on the back is the software of immo.
I want something cheap because you will make a time in my own car..HELP MEE FRIENDS!!
If we keep our own plate with the software and only change this indicators might happen Successfull;
We show photos of my own to see small and large plaque..
Uploaded with ImageShack.us
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #33 on: December 21, 2013, 06:56:37 pm »
no, it won't work
Offline sodmitris2
« Reply #34 on: December 21, 2013, 07:41:20 pm »
then what is the right software to work on my car?
have a shop; You can buy from you the right software and cable
« Last Edit: December 21, 2013, 07:44:11 pm by sodmitris2 »
Offline Chris01
« Reply #35 on: December 21, 2013, 08:39:03 pm »
The genuine vag commander kit is crazy expensive. Somewhere in the 4 digits area if memory serves. It's not worth it if you plan to only use it a couple of times.
Offline sodmitris2
« Reply #36 on: December 21, 2013, 09:17:38 pm »
somebody clonic ultimately can not work; and from being a cheap solution which to work; @chris how software WORKED;
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #37 on: December 21, 2013, 09:29:57 pm »
I agree:
othile clonic ekugcineni akakwazi ngomsebenzi; kanti kusuka ekubeni isixazululo eshibhile ukusebenza kuyo; @ chris indlela software wasebenza;
Offline sodmitris2
« Reply #38 on: December 21, 2013, 09:38:05 pm »
I agree:
WRITE english
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #39 on: December 21, 2013, 09:39:48 pm »
Yeah, my thoughts exactly. :laugh:
Offline sodmitris2
« Reply #40 on: December 22, 2013, 05:41:11 pm »
nothing????????????????
Offline twalters
« Reply #41 on: December 22, 2013, 11:09:43 pm »
This clock swap is very easy but not with less than version 21 (genuine avdi) or similar tools. Cheapo eBay tools are bad news. I repaired a dash from a 2009 a3 today that was read with super vag.  The dash was dead.
Where abouts are you Chris?
Offline Chris01
« Reply #42 on: December 23, 2013, 02:47:56 am »
The swap is pretty easy indeed granted you have the right equipment. I used 2006 clocks that matched mine and were also programmable with cloned software. What i haven't figured out is how to tweak EEPROM in order to make the coolant temp controller display boost. That said i've also got my eye on a 2008 cluster which won't be accessible by my current software. In case i got it, i'd need some help but i'm located in Greece, so unless you travel a lot, it's not going to work :laugh:. Dimitris is the one that needs help at the moment, but he's just as far.
Offline sodmitris2
« Reply #43 on: December 23, 2013, 07:38:42 am »
Thanks from the reply
What software WORKED you;commander 5.5?5.1?
chris You're from GREECE?
im greece
not understand not speak good English!
chris my mail : grigorosmb@hotmail.com
« Last Edit: December 23, 2013, 07:42:46 am by sodmitris2 »
Offline kalu
« Reply #44 on: December 26, 2013, 03:44:32 pm »
Not much progress here's a shot of the two EEPROMs side by side in a hex editor. There are too many differences to start taking shots in the dark..  :laugh: Anyone feeling lucky?
This function is most likely to be coded in the flash memory, not the eeprom!
