Author Topic: Mk5 GTI Instrument cluster swap  (Read 37149 times)
Offline Chris01
Re: Mk5 GTI Instrument cluster swap
« Reply #45 on: December 26, 2013, 06:44:11 pm »
This function is most likely to be coded in the flash memory, not the eeprom!
That's a good hint right there, thanks. The flash memory file is 512KB which makes it the largest file in the cluster, way larger than all the rest combined. Probably also the most complicated to work with.  :rolleye:
I guess that was the final nail in the coffin for the boost gauge project.  Assuming that clock assignment and staging are included in this file, along with other stuff, overwriting with the GT's ROM file will make the cluster display wrong km/h if it even works in the first place. The only thing i'd have to do is locate the part that controls the boost gauge in a 512kb file and then edit the GTI file accordingly.. piece of cake :jumpmove:
Offline georgekeemo
« Reply #46 on: November 09, 2014, 07:39:21 am »
Hey guys ,i'm new over here ,i have a 2004 mk5 1.6 fsi i'm searching for a maxidot for my car,not find anything ,i've understand that i need the a specific cluster fabricated before 31-05-2006. is that correct ? i've found this information on a other forum.
cheers !
cheehowfoo
« Reply #47 on: June 27, 2016, 10:02:04 am »
yes that will work
Hi there Eddie,
My '06 GTi with midline cluster's display is totally gone and I thought I might as well do a highland cluster retrofit. I am currently looking at this: http://www.ebay.co.uk/itm/222160209310?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT not sure if it's gonna work. My dealer said I have to get a particular cluster for my car and I'm sure that's gonna cost a lot! Your reply is much appreciated! Cheers.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #48 on: June 27, 2016, 04:52:57 pm »
Thats expensive!  You can get them for around £150 supplied and fitted. I have a set if you need one
Sent from my SM-G928F using Tapatalk
fotisth
« Reply #49 on: July 03, 2017, 02:49:04 am »
@Chris01  any progress on the epprom for the boost controller instead of the temp?
Offline NitrousOxide
« Reply #50 on: March 02, 2020, 04:21:21 am »
Can someone please post a BIN dump of their instrument cluster.  I used VDO editor to do the MK6 temperature gauge as a boost gauge successfully, so I wanted to visually see if I have the same option for the MK5 cluster as well.
