Author Topic: Weird behaviour when cold  (Read 974 times)
Offline alexmccabe
    • Alex McCabe
« on: October 28, 2013, 01:55:30 pm »
My car exhibits some weird behaviour when the engine is cold. If I hold the throttle pedal at one place whilst driving just after turn on, the car will kangaroo back and forth, sometimes quite violently. It's as if I am in a car with someone that doesn't know how to use the clutch properly. Once warmed up this doesn't happen.
I've also noticed weird idle when cold - mid temp. It kinda feels like it's misfiring on a cylinder, but not as jumpy, and it is quite infrequent. In my MK4 2.0 GTi, this was caused by the ignition coilpack, but it was a lot more aggressive.
What could be causing this behaviour? It is going in for a diagnostic tomorrow, but I am wondering if I can go into it with a bit of knowledge before hand.
MK5 Golf GTi 197BHP Tornado Red
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: Weird behaviour when cold
« Reply #1 on: October 28, 2013, 09:52:40 pm »
That sounds like a fuelling issue. Have you replaced your cam follower?
'07 Red manual
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #2 on: October 28, 2013, 09:56:21 pm »
Although a fuel supply issue wouldn't go away when the engine has warmed up. I don't know, sorry.
'07 Red manual
Offline alexmccabe
    • Alex McCabe
« Reply #3 on: October 28, 2013, 10:53:38 pm »
Yeah I replaced the cam-follower, though the old one was barely worn.
Offline Human Joist
« Reply #4 on: October 28, 2013, 11:39:37 pm »
I have the same symptoms with my dsg gti. I have just changed the sparkplugs as they had been in for 50k and that's improved the situation but now cured it. I was also thinking maybe coilpacks
Offline alexmccabe
    • Alex McCabe
« Reply #5 on: October 29, 2013, 03:43:03 pm »
The service today showed that the spark plugs were rusted and leaking. Got all new ones, but might have to replace one of the ignition coils.
Offline Human Joist
« Reply #6 on: October 29, 2013, 05:20:05 pm »
Is there a way for testing the coil packs at all
Offline Tha_Don
« Reply #7 on: October 29, 2013, 06:47:41 pm »
I have the same problem. I've changed the spark plugs but it didn't solve the issue. Let us know if you get it sorted please mate.
Offline joelee
Re:
« Reply #8 on: October 29, 2013, 07:33:04 pm »
Have you tried the temp sender unit as that controls the fueling and so on
Sent from my HTC One using Tapatalk
Offline alexmccabe
    • Alex McCabe
« Reply #9 on: October 30, 2013, 10:26:15 am »
Will do. It seems to be behaving much better now, but I will keep an eye on it. If you can afford to, replace the ignition coils as well.
Offline Tha_Don
« Reply #10 on: October 30, 2013, 08:28:46 pm »
Cheers mate. That was next on my list actually. Seeing as it's pay day tomorrow I might have to treat her to some  :happy2:
