Author Topic: what is the difference  (Read 2823 times)
Offline BLUE-STORM
  • GOLF GTI VS CLIO 172 SPORT
« on: October 29, 2013, 06:49:51 pm »
can any one tell me the difference between theses two part numbers :
06f 906 036f
and
06f 906 036g
both are injectors     is the   G   for a GTI  and the F   for a S3 ???
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ut3jrfr26ri449ug3ah2g24tpe&/topic,19740.0.html
Re: what is the difference
« Reply #1 on: October 29, 2013, 06:53:33 pm »
S3 flows more than the normal GTI.... someone clever will be able to tell you the exact spec.
Offline joelee
Re:
« Reply #2 on: October 29, 2013, 07:31:33 pm »
I am sure the s3 one is bigger od than the gti one
Sent from my HTC One using Tapatalk
« Reply #3 on: October 29, 2013, 07:34:18 pm »
06f 906 036f is definitely a S3 injector that flows about 15% more than the standard FSI injector.
iirc ed666999 had 06f 906 036g injectors installed with his k04 conversion.
Offline doylebros
« Reply #4 on: October 29, 2013, 07:53:55 pm »
G dropped to supersession to 06F 906 036 A which is used in both VW & Audi
However, it depends on which engine for example
A and F  can be found in both VW & Audi but it chassis number dependant as to when.
>>1K-6-190 000 is Ending in A for engines AXX,BWA,BPY
1K-6-190 000>> is Ending in F for engine BYD
When fitting required complete with repair kit 06D 998 907
Information from ETKA7.4
Offline BLUE-STORM
« Reply #5 on: October 29, 2013, 10:33:22 pm »
ive just had a k04 set up fitted and 06f 906 036f injectors fitted , my old ones were the 06f 906 036g ones ,  so was jsut wondering if i needed to change them at all
« Reply #6 on: October 29, 2013, 10:54:52 pm »
Well... if F injectors are on the Ed30 and you are running K04.. then they will be fine.
