Author Topic: Only Those With the Right Type of Brain Should Look At-'missing square puzzle.'  (Read 989 times)
Offline doylebros
'Click on the missing square puzzle.'
Too much for me! :stupid:
Can you figure out how he does it?  It is based on a phenomenon known in mathematics as the 'missing square puzzle.'
http://www.flixxy.com/most-popular-videos.htm
  • -Receive: 291
If I remember rightly, this happens because you only think it's full. When he takes out the three squares, there are gaps in the rectangle left behind but they are too small to notice. They add up to the size of the three squares. It's essentially the same as this:
If you drew a line from corner to corner, essentially drawing the hypotenuse, you'd find that in the top triangle, the hypotenuse isn't straight but curves in. This means there's a "gap", but it's too small to be seen/noticed. If you look at the bottom triangle, the hypotenuse is straight and the "filled in" bit is from the missing square:
« Last Edit: October 29, 2013, 07:42:37 pm by stealthwolf »
Offline doylebros
You've got the job, you start on Monday - just need to agree wages! :congrats:
  • -Receive: 291
No thanks. I'm happy with my job. Until Jeremy Twunt destroys it.
Offline Marc-5-GTI
*Goes and buy a choclate bar for free chocolate*
