Author Topic: Preventative maintenance before having Stage 1 remap...  (Read 2054 times)
Offline Welshman Adam
« on: October 30, 2013, 04:59:02 pm »
Hi all,
I'll keep it simple, I'm looking at having my ED30 remapped in the New Year.  She's nearly on 70,000 miles - what should I consider replacing beforehand?
Off the top of my head I'm thinking DV, perhaps the cam follower?
Any advice appreciated.
Cheers,
Adam
Black ED30 No. 1,328 - Gone but not forgotten...
Offline wilmott1980
Re: Preventative maintenance before having Stage 1 remap...
« Reply #1 on: October 30, 2013, 05:27:08 pm »
I would definitely check both of them and perhaps check the seals on the intercooler hoses.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #2 on: October 30, 2013, 06:06:36 pm »
^^ sound advice
Defo check PCV, DV, cam follower and if they haven't been changed for a while: spark plugs  :happy2:
Offline Homer
« Reply #3 on: October 30, 2013, 06:39:30 pm »
Is there a DIY guide on checking seals on the intercooler?
Offline trs888
  • -Given: 17
  • -Receive: 20
« Reply #4 on: October 30, 2013, 07:02:27 pm »
^^ sound advice
+1
« Reply #5 on: October 31, 2013, 06:30:00 am »
Cheers all.
I changed the PCV a few weeks ago. DV is the original one, so I'll do that.
Cam follower is a little beyond my expertise. Rough cost to have it done by a garage?
Plugs are about a year old and have done 10K.
Offline bigeyd
  • -Receive: 31
« Reply #6 on: October 31, 2013, 06:54:55 am »
Half an hours work,don't ask VW they will have your pants down
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #7 on: October 31, 2013, 08:34:51 am »
:grin: :grin:
'07 Red manual
Offline alexmccabe
    • Alex McCabe
« Reply #8 on: October 31, 2013, 08:56:06 am »
Get a smoke test to make sure there are no leaks in your boost system.
MK5 Golf GTi 197BHP Tornado Red
« Reply #9 on: October 31, 2013, 09:39:56 am »
In comparison to changing the PCV, how difficult is it to change the cam follower?  I found the PCV to be pretty easy once I got the air box out of the way.
Offline flashp
  • -Receive: 65
« Reply #10 on: October 31, 2013, 12:32:04 pm »
Whoever you've chosen to do the work for you should be well aware of what needs checking. They should want to avoid putting you or your car at risk and possible reprocussions relating to increased load on mechanical components.
For instance, they may ask about your servicing regime if they are not your servicing agent, they should carry out an ECU scan, check your brakes & tyres. Everything you depend on to be safe and your car to be mechanicaly sound should be reviewed.
If they don't make what you feel are sensible recomendations or observations regarding your car then find another tuning agent.  :happy2:
Incidentally, you'll be very close to needing a cam belt change by then I would imagine.
« Last Edit: October 31, 2013, 02:03:50 pm by flashp »
Gone but not forgotten :-)
