Author Topic: Whole car misting up.  (Read 6008 times)
Offline adminkatana
« on: October 30, 2013, 08:57:47 pm »
Hello,
I've always found my MK5 a bit slow to de-mist. Talking a good 5-10mins to clear the windscreen before setting off. But this morning was awful, even the dials on the dash and rear view mirror suddenly misted up just after leaving.
Has anyone else experienced this? Tried quite a few things. New Pollen filter, can't find any damp in the car, closing the vents in evening, silica sachets in the door card pockets etc.
Be interested if anyone has any possible ideas for a solution? Thinking of getting some Rain X Anti Fog tomorrow to see if that works.
Thanks!
Saintsteve
Re: Whole car misting up.
« Reply #1 on: October 30, 2013, 08:58:38 pm »
You have damp somewhere I'm afraid
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #2 on: October 30, 2013, 08:59:47 pm »
Try the Air con!  that removes moisture from the air and will clear the whole car in no time, that'd what it's there for, not just to keep you cool in the summer
« Reply #3 on: October 30, 2013, 09:02:40 pm »
^^^^ This.
My A/C is never off, I just adjust the temp' accordingly to my (or the occupants) requirements.
Offline bower
« Reply #4 on: October 30, 2013, 09:38:00 pm »
mines the same it takes ages to clear. everyone says put a/c on but ive got climatronic, how do u demist quick? i just set it to high but doesnt seem to work, should i be putting something else on?
Offline xjay1337
  • -Receive: 377
« Reply #5 on: October 30, 2013, 09:39:30 pm »
Normally moisture is in the car.
It helps to start by leaving some of those silicone bags in there.
Also drive round with the heaters on full but with the windows down and the recirculation on.
Eventually it will clear itself out.
Offline chrispygti
« Reply #6 on: October 30, 2013, 10:10:09 pm »
If none of the above work you might have a slight leak somewhere normally around the door seals.
  • -Receive: 453
« Reply #7 on: October 30, 2013, 10:16:31 pm »
Have you used the top left button of the three climatic control dials for fast windscreen demisting?
Offline adminkatana
« Reply #8 on: October 30, 2013, 10:18:18 pm »
Thanks for all your suggestions, I will give them a go and also have a good look around the car at the weekend for any leaks/ damp.
Thanks! ^Yep, always press the 'windscreen button?' not sure of technical term for that button  :smiley:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #9 on: October 30, 2013, 10:21:43 pm »
A/C cures most ills Re: Condensation... however, moisture in the car (somewhere) is mostly likely the culprit for misting that won't dissapear.  It's also worth looking at your pollen filter to see whether it's completely blocked (easy job underneath the glovebox) :happy2:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #10 on: October 30, 2013, 10:23:52 pm »
it is common that these cars do mist up quite badly when the weather changes
my old car did it, my new one and loan cars
Cluster and Key coding
Location Great Yarmouth
Offline Horatio
  • -Receive: 39
« Reply #11 on: October 30, 2013, 10:31:40 pm »
First time I had this in the mk4 this year, but was really, really bad  :fighting: Really bugged me all the way home yesterday. I gave the door shuts and all around the doors a good wipe down as they were still wet from all the rain over the weekend.
No condensation this morning  :jumpmove:
I think B&Q sell quite large moisture absorbers. I think Penguin is the brand. These work really well.
Dirty windows inside really attract moisture as well.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #12 on: October 30, 2013, 10:41:24 pm »
must be the dirty windows on mine :signLOL:
Offline k909
  • Diesel mafia
« Reply #13 on: October 31, 2013, 12:18:34 pm »
Wow, thought this was just me haha
Offline SkyJawa
« Reply #14 on: October 31, 2013, 03:00:54 pm »
Missus car had this yesterday, I guess because it was valet'd before picking up so will still be a bit damp in there at this time of year.
Put the climatronic onto the windscreen demist button and it was soooooo slow to clear.....
