Author Topic: Just had an interior fire caused by an electrical short...... VW's reply sucks!!  (Read 12566 times)
Offline Polo6n1600i
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
looks like my detective work was right
hope you get it sorted
Cluster and Key coding
Location Great Yarmouth
Offline Polo6n1600i
I'll be on the phone to vw tomorrow. See what customer services say about it.
Offline Polo6n1600i
Called and spoke to VW customer services - advised me to take it back to the local dealers for inspection. Asked them how am i meant to do that as the glovebox is out & the battery is disconnected. if I drive it back to them with the glovebox out, the airbag warning light is going to come on (due to switch insude glovebox for deactivation) - warning light is already on as we had to move the car while the glovebox was disconnected!
They didnt want to take the responsibility and i would need to sort something out with the dealers directly. So called Camerons - they said exactly the same - they cannot guarentee that if there was an accident that the airbag would deploy if the warning light was on the dash!
See what they come back with later!
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Get them to supply a low loader or if your a member of RAC/AA get them to take it there. :happy2:
Offline Polo6n1600i
I have RAC, not sure if they would do that though??
Offline Scottymon
  • -Given: 83
  • -Receive: 125
Why?  I've done it before now with the AA... if you haven't got home start, then get the car down the road a little way then call them; he's not going to be able to fix it, so will take you to a garage... :happy2:
Offline xjay1337
  • -Receive: 377
1) You can disable the auxillary heater in Vagcom
2) The Auxillary heater only is "on" during heating, if you have the heaters off the Aux heater is not on.
3) The airbags are supposed to deploy even if there is a fault on. Just that the passenger side will go off even if there is no-one sat there (normally they would only go off if someone is sat in the seat).
4) Either fix it yourself or drive there with the heaters off?
Offline Polo6n1600i
Thats what i thought too! The car is so low anyway the chances of getting a low loader under it are slim enough!
Offline xjay1337
  • -Receive: 377
Why not just remove the fuse from the Auxillary heater and drive it..
I doubt you are so low you can't get on a low-loader.  :happy2:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Disable the AUX heater by removing the fuse in the engine bay
Coding it out with Vag com won't stop it
As for the airbags
If there is a fault in the system then NO airbags will work
Offline Polo6n1600i
Which fuse is it? i thought it was the 200W fuse. but removing it just brings the battery warning light on!
Offline Polo6n1600i
Ok its the 100W one!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Fuse 6 (100A)
Offline xjay1337
  • -Receive: 377
They do on Vauxhalls  :signLOL: :signLOL: :signLOL:
Figured VWs were the same.
