Author Topic: Stupid air con on or off?  (Read 10577 times)
Offline J12spk
  • VW PERVERT
« on: October 31, 2013, 10:37:15 pm »
Standard air con owner here..........
So if the light on the air con / econ is on, does this mean air con is on or off??????????????
I just can't work it out!!
 :fighting2:
Das Auto
Offline GTI power
Re: Stupid air con on or off?
« Reply #1 on: October 31, 2013, 10:39:27 pm »
Off. Econ = economy as I understand.. No air con.
Offline SkyJawa
« Reply #2 on: October 31, 2013, 10:53:10 pm »
Yep as above Econ for better fuel economy, turns off the ac otherwise it's on
Offline Llew
  • -Given: 45
« Reply #3 on: October 31, 2013, 11:27:48 pm »
Light on = aircon off
Light off = aircon on
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
« Reply #4 on: October 31, 2013, 11:37:52 pm »
I take it you might have a problem with your aircon?
You would be able to tell which is on or off if you turn temp gauge to lowest.   :wink:
Offline J12spk
  • VW PERVERT
« Reply #5 on: November 01, 2013, 06:59:45 am »
Thanks guys
Das Auto
Offline alexmccabe
    • Alex McCabe
« Reply #6 on: November 01, 2013, 12:09:48 pm »
I spent a LONG time trying to figure this out. The reason it was s much trouble for me (and the people on here who helped me out) was because the air-con was misbehaving. If the E-Con light is on, Air-Con is off. If you can't tell the difference between the two then your air-con system is buggered.
Could need a simple re-gas, it could be the pressure switch (you better hope it's one of these two) or it could be the pump.
MK5 Golf GTi 197BHP Tornado Red
Offline Polo6n1600i
« Reply #7 on: November 01, 2013, 12:32:42 pm »
also didnt VW change the button operation at some time in 2005/2006? Prior to that is was you pressed the button for economy model (i.e A/C off) - but people were confused by it so change it to A/C button - light on = A/C on. Light off = A/C off.
So it could depend on the age of your car!
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #8 on: November 01, 2013, 07:15:47 pm »
I changed my control panel for the newer version with AC button instead of ECON which lights up when AC on. A simple and possibly pointless mod, but I prefer it.
Jas
VCDS (Preston, Lancashire)
Offline xjay1337
  • -Receive: 377
« Reply #9 on: November 01, 2013, 07:19:04 pm »
Yes they did
I don't see how it can be confusing really.
Econ=Economy mode.
The climatronic cars are the same with an ECONbutton...
Offline skard
  • -Receive: 245
Re:
« Reply #10 on: November 02, 2013, 12:15:06 am »
Jas
Just so you know, I did this in my 11/2005 TDI and aircon stopped working, it was being switched off right away at the ECU, but on the surface all seemed ok.
A VCDS measuring block confirmed it.
Happened to others also but doesn't necessarily mean yours will be affected the same.
Offline torque777
Re:
« Reply #11 on: November 02, 2013, 07:34:05 am »
We have a golf and jetta ...56 plate jetta with econ button 57 plate golf with ac button ...we never press econ on the jetta and leave air con on ...these are both diesels and tbh it makes no difference to fuel economy at all in fact the jetta is better on fuel and returns 600 miles to tank were I get 520 in the golf lol
sent using my own fingers
Offline Sebas_theFish
Re:
« Reply #12 on: May 04, 2021, 06:13:12 am »
Jas
Sorry to dig up such an old thread but I've just done the same, did you ever find a solution for
this or work out why it happens?
« Reply #13 on: May 04, 2021, 07:41:42 am »
Does anyone know why this button reversal occurs? I assume it's just the software on the climatronic controls and there's nothing you can do about it...
Sent from my Samsung Smart Fridge
