Author Topic: Idling high and self revving?  (Read 4198 times)
Offline TForrest94
« on: November 04, 2013, 12:57:23 am »
Alright guys
As some of you may have gathered I'm not very talented when it comes to mechanics
So for the last week or so the golf has been playing up, it idles fine then within seconds it's raises from 700 to about 1200rpm if I rev the engine it drops back down again before raising
As well as this every now and when I go to change gear the engine will stick at 2000 until I rev or release the clutch
I've read it could be the pcv but wanted some confirmation from you guys, gonna do the dip stick test tomorrow and see if that shows anything could it be anything else?
As always cheers for the input
Tommy :notworthy:
Its just a way of life.
Offline phem0r
Re: Idling high and self revving?
« Reply #1 on: November 04, 2013, 08:39:25 am »
My vote is the PCV valve, a friends seat leon cupra was doing the exact same self reving and he had the PCV valve replaced to resolve it
MK5 Golf GTi - Revo Stage 1 - Forge TwinTake - Milltek Catback - Eibach Sportlines
Saintsteve
« Reply #2 on: November 04, 2013, 08:40:18 am »
As above.
Faulty PCV valve assembly.
Offline TForrest94
« Reply #3 on: November 04, 2013, 02:14:09 pm »
Cheers guys
How much are the parts and how hard is it to change? Had the cam follower changed 2 weeks ago and havent got a sh*t load of money to throw at a garage
Also could the garage have caused danage to it whilst doing the follwer?
Offline phem0r
« Reply #4 on: November 04, 2013, 02:19:09 pm »
It is very easy to change, have a look at this thread, it gives you the part number and shows you where it is on the engine - basically it's on top under the engine cover and it's 4 bolts
http://www.mk5golfgti.co.uk/forum/index.php?topic=44709.0
Offline edd666999
  • -Receive: 89
« Reply #5 on: November 04, 2013, 03:03:45 pm »
Im selling the latest revision "N" pcv. Perfect working order, take a look:
http://www.mk5golfgti.co.uk/forum/index.php/topic,73929.0.html
Offline Homer
« Reply #6 on: November 04, 2013, 08:18:27 pm »
Defo PCV valve. I had exact same issue not long ago. Don't go to a dealer whatever you do, they will say it's an injector misfiring and try and charge you for a new one.
Offline TForrest94
« Reply #7 on: November 05, 2013, 02:39:45 pm »
I might have to take that off your hands
I'm just in two minds whether to do the pcv delete or repair it, what's the best method?
Offline edd666999
  • -Receive: 89
« Reply #8 on: November 05, 2013, 06:37:05 pm »
There are pros and cons to both, do some searching on the bsh Pcv delete and revo delete, few threads on the subject already.
Offline TForrest94
« Reply #9 on: November 15, 2013, 05:59:35 pm »
Alright guys got a suprese last week ended up in New York for a few days, lucky me!
While I was out there im got a hold of a 42dd stealth catch can, solves the problem of the sh*tty pcv and doesn't create back pressure like a block off plate win win!
Aiming to fit it tomorrow so I can finally drive it properly again!
