Author Topic: HID kit problems  (Read 2465 times)
Offline will_15
HID kit problems
« on: November 04, 2013, 09:35:03 pm »
So I've had Depo projectors since the summer, as it's now dark 80% of the time I drive thought it was about time I fitted an HID kit...
This is the kit I went for (they are all made in the same Chinese factory right? http://www.ebay.co.uk/itm/330379335700). It worked well the first couple of times but I've had to put normal H7's back in recently as I just can't rely on it to work.
With the engine already running the ballasts fail to ignite when they are switched on, commonly the passenger one fails to light, often it's both. After about 10 minutes of the engine running they will both eventually turn on then work fine for the rest of the journey thereafter, can be switched on and off many times whilst the engine is still on.
Research suggests this is a low voltage problem, I've disabled 'leaving home' lights already and start the car with the switch all the way to the left in 'off'. Battery is new. http://www.ebay.com/gds/HID-XENON-CONVERSION-KIT-TROUBLE-SHOOTING-/10000000001215090/g.html
Anyone had similar issues? Anyone had an HID kit that's worked without problem from day 1 that they can recommend?! Or I could just buy a new set of bulbs & ballasts and try again...
Thanks for any help, i don't want to go back to regular H7's they just don't compare to xenons now I've had a taster of them :confused:!
Offline john a
    • The Veneers Cover Band
Re: HID kit problems
« Reply #1 on: November 04, 2013, 09:48:49 pm »
I had an HID kit in some Hella projectors on my Focus and found they had the same problem.
Often, a sharp whack with the back of my hand would make them jump into life, which might suggest a stuck or sticking relay being freed. I never did get to the bottom of the problem and sold the car fairly soon afterwards. I had a combined boost/voltage gauge on that car and as far as I could make out, the battery was also good too and the car getting the necessary voltage it should have been.
Offline jackrobinson
Offline SkyJawa
« Reply #3 on: December 08, 2013, 02:02:27 pm »
Had a similar issue with ones fitted to my old Leon. However it only ever happened when starting the car with the lights already on, if you waited until the car was running they used to be ok.
Offline mo
« Reply #4 on: December 11, 2013, 03:49:38 pm »
Had the same issue as SkyJawa until i changed my battery which apparently was on its way out. Some minor coding in VagCom also helped. Resistors/Cancellers are not required if you have access to VagCom.
2007 Ed30 Superchips Bluefin Stg 1
RNS510 & MDI
Offline panarasgr
« Reply #5 on: December 11, 2013, 07:23:16 pm »
can you please advise the exact steps required to get this fixed from vcds?
Golf Mk5 GTI DSG,APR Stage 2, K&N typhoon intake, Forge blow off,Revo PCV delete, 3'' Downpipe decat,
Offline mo
« Reply #6 on: December 13, 2013, 12:27:19 am »
Basically you need to change the coding for your lights to Xenon lights without shutters, and also turn off the cold start check for dipped beam iirc.Did mine almost a year ago but only took about 5 mins to find and change the settings.
RNS510 & MDI
Offline biglad65
« Reply #7 on: December 13, 2013, 10:16:29 am »
i did this and mine work fine  :happy2:
