Author Topic: Passenger door wont open??  (Read 26691 times)
Offline doylebros
  • -Receive: 310
Re: Passenger door wont open??
« Reply #30 on: December 11, 2013, 05:04:09 pm »
Pleased they sorted it for you.
What was the part number of the module - seems expensive?
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #31 on: December 11, 2013, 06:33:23 pm »
Says
5K0959703VW3
On the invoice - Shown as a Motor ??
£130.94 + VAT
Offline doylebros
  • -Receive: 310
« Reply #32 on: December 11, 2013, 06:40:50 pm »
Says
5K0959703VW3
£130.94 + VAT
That's because you've had the window motor regulator replaced "not the lock module assembly"!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #33 on: December 11, 2013, 06:56:44 pm »
you could have bought the motor of ebay for around £30 and you could have changed it yourself
only 3 screws hold it in place, although you would have had to get the door card off first
Cluster and Key coding
Location Great Yarmouth
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #34 on: December 12, 2013, 06:22:57 pm »
Spoke to VW about what they replaced under the above part number reply is below
" I can confirm that this item is correct – it is actually a motor and control unit combined. we cannot change the part description as this is as described by Volkswagen but for warranty purposes we know exactly what has been replaced "
Did anyone know this ?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #35 on: December 12, 2013, 06:49:49 pm »
It is the door controller for the rear door which also is the window motor
as i said it could have been a cheap fix, at least you have 2 yrs warranty on it. although that won't be transferable if you sell the car
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #36 on: December 12, 2013, 07:43:42 pm »
Better not sell it then  :smiley:
GWGTi
« Reply #37 on: January 18, 2017, 02:42:06 pm »
garrardrj Did VW ever tell you how they got the door open? I have exactly the same problem on my passenger door of my 3 door Mk5 GTi. I've tried the trick with the pick and doesn't seem to have worked. I've got no electrics on the passenger side at all (central locking, window), even if you try from the drivers side controls or the key, so I'm pretty confident it's a motor like yourself or the wiring loom. There is something also draining my battery so I'm hoping it's all linked together.
If I can just get this door open I can look!
