Author Topic: Retro-fitting armrest with working air vents  (Read 5955 times)
Offline paulw123
  • -Receive: 47
« on: November 07, 2013, 01:54:14 pm »
So I've finally got a leather armrest, after looking for ages on Ebay.
Ordered the additional air ducting from the dealers today. He reckoned there was only 1 option, item 10, even tho I have seen photos of a single pipe. It appears to be split into 2 and must fit over the gear knob ?
Has anybody fitted this successfully?
For £11 I thought I would give it a go. Hopefully it will be the single version and can fit around the gear stick.
Offline Simon_2.0t
Re: Retro-fitting armrest with working air vents
« Reply #1 on: November 07, 2013, 02:04:37 pm »
Sounds good mate, how much did you pay if don't mind saying. Looking out for one for mine.
I think there is two versions dependent on if have 6 disc changer in the armrest.
Here is a few fitting guides:
http://www.golfmkv.com/forums/showthread.php?t=135718
http://www.myturbodiesel.com/1000q/a5/center-console-removal-mk5.htm
Hope goes well.
Si
Offline paulw123
  • -Receive: 47
« Reply #2 on: November 07, 2013, 03:17:34 pm »
Thanx Simon,
Yeah there are 2 versions, cubby hole and cd/mdi/usb type. The cubby hole type also has different air ducts which split to cool the box, i guess to keep your sarnies cool. I got the cd type with cd player removed. Not what I wanted, but it took me ages to find this one. Hoping to fit single din universal tray into the hole left behind. Its in pretty good condition, especially the rear air vents & cup holder, guess these don't get used much in GTI's  :wink:
I got it from www.nirro.co.uk, email parts@nirro.co.uk .No screws with it and it was only bubble wrapped, no box.
It was £163 delivered thro Ebay.
Offline doylebros
  • -Receive: 310
« Reply #3 on: November 07, 2013, 05:03:10 pm »
This was posted today and will help you no end with your install
http://www.mk5golfgti.co.uk/forum/index.php/topic,75108.0.html
It's ETKA online go to illustrations 819-030 in the body section for golf 2007 you see the pipe work.
Then illustration 863-60 for the full armrest breakdown!
Offline paulw123
  • -Receive: 47
« Reply #4 on: November 08, 2013, 01:06:25 pm »
wow thanks for that.
that is exactly the images the dealer had up, item10, fingers crossed  :happy2:
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #5 on: November 13, 2013, 08:48:56 pm »
You mean the large pipe that goes under the centre console I take it rather than under the armrest. There are two versions of the pipes - the earlier cars had the one that splits around the gearstick, later ones just to the one side
Offline paulw123
  • -Receive: 47
« Reply #6 on: November 15, 2013, 04:16:29 pm »
you're spot on there, even tho the dealer image was of the split one around gear stick, what actually arrived was the single left hand version  :happy2: which should make it easier to fit.
why does the euro cup holder only come with 1 mat in   :fighting:  still gives me a cheap upgrade....
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #7 on: November 15, 2013, 04:41:25 pm »
There is a chap on eBay who sells both mats and the bottle opener/divider for £9.99  :happy2:
