Author Topic: Braking Question  (Read 2153 times)
Offline CarlW
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92229.msg927100.html#msg927100
Re: Braking Question
« Reply #15 on: November 07, 2013, 07:22:35 pm »
Thanks for all the info. I've taken it all onboard so shall wait and see what happens in the near future when i get the motor
Offline xjay1337
  • -Receive: 377
« Reply #16 on: November 08, 2013, 04:22:37 pm »
If your going to be adding power then upgrade your brakes instead of new pads, discs and fluid.
As mentioned, R32/S3 for valve and a very noticable improvement or 4 pot calipers such as the Porsche Brembo 986 kit (otherwise known as the NQSBBK on here) which are a LOT lighter weight option but cost around £800-£900 if your sourcing the parts for the BBK yourself or from £600 second hand on here.
Combine an BBK with some better rears such as S3 or Caddy 2k's.
Lots of threads on all the above.  :happy2:
I'm sorry, I disagree.
More pots and/or a larger caliper and/or a larger disc does not automatically give better braking. It may help improve fade but only because of thermodynamics or something like that. Larger surface area means more cooling and more ability to maintain heat.
The main problem is fade.
You can fit 18 piston calipers on a 700mm disc but you can only stop as fast as the tyres can grip. The tyres are the limiting factory ultimately.
The best bang for buck upgrade would be high performance pads and brake fluid..... and is all you NEED.
  • -Receive: 427
« Reply #17 on: November 08, 2013, 04:57:34 pm »
^^^^ No need to be sorry!  :laugh:
Offline GarethB
« Reply #18 on: November 08, 2013, 05:10:00 pm »
Sorry Jay, but I disagree.
Without going into a mass physics debate, if your GTI (with standard 312mm front brakes) is rolling alongside say, RedRobins GTI (with 330mm AP four pots), and you both were to anchor up at any speed - he will stop first  :smiley:
Offline xjay1337
  • -Receive: 377
« Reply #19 on: November 08, 2013, 05:12:19 pm »
No need to be sorry. ;)
On the same tyres on the same road, all things being equal, I can't see how.
You are limited by your tyres. If your tyres can only hold 0.8g of braking you can only stop at 0.8g... even if your brakes are capable of pulling 1.2 , for example?
Correct me if that's not right.
However after 3 attempts while his would still stop i would imagine the stock brakes would be suffering with some amount of fade.. THAT'S where big brakes kick in.
Offline GarethB
« Reply #20 on: November 08, 2013, 05:15:42 pm »
I think we need a DaveB in here really....
although I agree with your thoughts on fading - my APs are unreal. They just feel stronger than standard or R32 brakes that were fitted before, and never ever seem to fade  :happy2:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=oiq60lpkpun4mpli8h3lms2iaf&/topic,19740.0.html
« Reply #21 on: November 09, 2013, 09:56:51 am »
Braking from high speed and you'll notice the difference between setups... take 3 GTIs. One with 312mm... one with 345mm and one with 362mm 4 pot. Braking from 100MPH, and you clearly see the benefit.
Offline Tinytim
« Reply #22 on: November 09, 2013, 10:07:06 am »
I have VWR 6 pots fitted to mine and couldn't imagine going back to standard gti brakes.
The difference really is night and day in terms of stopping ability
When travelling at speed the VWR brakes enable you to loose speed at an amazing rate.
Everytime I drive my other halfs car I nearly fail to stop because I am so used to my brakes where you only have to touch the pedal to stop.
Best upgrade on my car in my opinion.
  • -Receive: 427
« Reply #23 on: November 09, 2013, 10:55:40 am »
Did you make that up or find it on the interweb??  :signLOL:
If the tyres are the same on both cars (one with the OEM set up and one with a BBK set up) of course the car with better brakes will perform better!
Offline flashp
  • -Receive: 65
« Reply #24 on: November 09, 2013, 11:16:19 am »
I can't say I've noticed a problem with the brakes on my GTI at all, especially for a 200bhp hatch... more than good enough.
 Large BRAKES do not improve braking automatically.
Fit new OEM discs, Ferodo DS2500 pads and ATE Superblue fluid.
Do this unless you are tracking your car or planning to go beyond stage 1. I ran standard brakes with Revo stage 1 on the road and it was fine.  :happy2:
Gone but not forgotten :-)
Offline Tinytim
« Reply #25 on: November 09, 2013, 01:52:44 pm »
Get some of these. Expensive but an amazing product, once you've had them you'll never want to go back.
http://www.goapr.co.uk/products/brakes_vwr_vag_a5.html
Offline xjay1337
  • -Receive: 377
« Reply #26 on: November 10, 2013, 01:28:51 am »
I don't make things up :P
You can only stop as fast as the tyres will allow you (ultimate braking)
Larger/better brakes will be less susceptible to fade and thus allow you to brake more reliably more of the time (eg in repeated runs) .
