Author Topic: DAB Antenna Routing  (Read 1344 times)
Offline NezEd30
DAB Antenna Routing
« on: November 07, 2013, 06:13:22 pm »
Going to be fitting my RCD 510 to my edition 30 this weekend and I have a DAB antenna which goes on the windscreen, anyone fitted one of these and how did you route it to the windscreen?
Offline brookesb32
  • -Given: 59
  • -Receive: 75
Re: DAB Antenna Routing
« Reply #1 on: November 08, 2013, 09:05:23 pm »
Had one in the past, ran it up behind the glovebox. If you take the side panel off the dash you can pull through and then up the edge of the pillar and tuck it up the pillar at the windscreen and stick on
