Author Topic: 85k overhaul - questions  (Read 2290 times)
Offline Simmo
« on: November 08, 2013, 11:04:00 am »
Right, I've decided my beloved GTI needs a thorough going over before the winter and to make sure its running spot on. (It had a full VW service at 78k when I bought the car)
I'm going to fork out for another full service, plus ask the garage to look at:
- Check cam follower
- New diverter valve - revision G or Forge (looking to go Stage 1)
- Check Fuel Pump
- Check charcoal canister and piping (last vagcom report showed up P0441 - 002 - Incorrect Flow - Intermittent from Emission Control Sys)
- Check intake manifold runner v157 (last vagcom report showed up P3137 - 001 - Basic Setting not Completed - Intermittent from Intake Manifold Runner Control)
- Check PCV
- Check Cam Tensioner (to hopefully cut down the dreaded diesel idle sound)
- Check Plugs, Leads and Coil
- Reset DSG basic settings using vagcom (1st and 2nd aren't quite as smooth as they were when I bought the car)
- Check starter motor as cold starts isn't as smooth as I'd like
- Look into vagcom fault code P0642 - 002 - Low - Intermittent from Sensor Reference Voltage A: Circuit
- Check Bushes and steering rack - minor play in steering from centre point
Can anyone suggest anything else that needs checking please?
Cheers, Andy
Offline Veee-dubber
Re: 85k overhaul - questions
« Reply #1 on: November 08, 2013, 11:35:22 am »
worth checking your badgervalve aswell bud, just to be safe  :happy2:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=odee5ua5m5hh1cf7slp37deen7&/topic,19740.0.html
« Reply #2 on: November 08, 2013, 11:36:53 am »
 :signLOL:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #3 on: November 08, 2013, 11:47:27 am »
Check battery terminals / earth strap and condition of battery, check play in the alternator pulley, check condition of belt - check anything that's likely to leave you stranded.
Join AA and buy a warm coat, job done. :happy2:
Offline Simmo
« Reply #4 on: November 08, 2013, 12:13:22 pm »
Cheers guys
I've heard the badgervalve can be a vicious b**tard if left un serviced! I'm waiting for APR to offer a complete replacement using Otters instead  :smiley:
Offline richtung
  • -Receive: 56
« Reply #5 on: November 08, 2013, 12:34:25 pm »
You haven't mentioned it but I assume the DSG service was carried out when it went in for the full service?
Might be worth getting the fuel filter changed if its never been done?
hope this helps
Rich
Edit: Forgot to add: If you have a sunroof, might be worth getting the guide rails cleaned and lubed.
« Last Edit: November 08, 2013, 12:42:12 pm by richtung »
Offline Simmo
« Reply #6 on: November 08, 2013, 12:51:42 pm »
Yup - had the DSG serviced at 78k with the full service
Cheers I'll add it to the ever growing list!
No sunroof on this one
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #7 on: November 08, 2013, 08:28:55 pm »
Winter Tyres?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #8 on: November 08, 2013, 11:08:24 pm »
I had a problem with that. I think VW resolved that issue on the TSI engine  :happy2:
Offline Simmo
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #10 on: November 09, 2013, 02:38:47 pm »
Offline Human Joist
« Reply #11 on: November 09, 2013, 04:26:31 pm »
VW told me that the fuel filter on these was a non serviceable part when I went to order it for replacement
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #12 on: November 09, 2013, 04:44:17 pm »
Yeah, it's locked in kryptonite and your superman... tis more bullsh*t mate.
Here's a good DIY: http://www.golfmk6.com/forums/showthread.php?t=28302
Part Number: 1K0 201 051 C
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #13 on: November 09, 2013, 04:55:31 pm »
Although they are correct in a fashion, that being that VW don't service the fuel filter, like they don't service the cam follower, but IMHO both need attention.
Offline Human Joist
« Reply #14 on: November 09, 2013, 07:28:20 pm »
Cool will change it then. Had a look other day and as soon as I tried to move it one of the clips snapped and I had to repair it with a zip tie. It was then that I rang VW and they told me the non service rubbish. I asked about the clips and they are part of the fuel lines so I presume all 3 will snap and be held on with zip ties. They seem brittle. Probably because they have never been moved.
