Author Topic: Mk5 gti exhaust onto a 1.9 tdi  (Read 3986 times)
Offline J12spk
  • VW PERVERT
« on: November 11, 2013, 07:21:07 am »
I imagine this question has been asked and discussed a million times!
As the title, is this simple enough to do? Just the back box part. Will it be ok for a petrol exhaust going onto a diesel?
Any help gratefully received
James
 :fighting2:
Das Auto
Re: Mk5 gti exhaust onto a 1.9 tdi
« Reply #1 on: November 11, 2013, 07:50:14 am »
yep its been asked once or twice :grin:It will fit but needs adapotor pipe that a exhaust place can make for you
Offline George10
« Reply #2 on: November 11, 2013, 08:02:55 am »
You can cut two slits in the pipe and slide it over the standard pipe, then clamp it.
Long life can make you an exhaust for around £250
Offline xjay1337
  • -Receive: 377
« Reply #3 on: November 11, 2013, 08:59:32 am »
Don't bother putting a GTI exhaust on.
The pipes (tops) are still really small and it will be quieter than a TDI as the 1.9 TDI only has the one backbox - at the rear of the car. It'd be better, and cheaper, to go to a local custom exhaust shop and have them put some bigger tailpipes on..
I had a Piper Catback on my old car which comes with a lifetime warranty.
« Last Edit: November 11, 2013, 10:24:46 am by xjay1337 »
Offline skard
  • -Receive: 245
« Reply #4 on: November 11, 2013, 10:08:11 am »
James
 :fighting2:
Easy and well worth it for a subtle improvement to the back end.
The difference in bore between a 1.9 diesel and a GTI is quite a step, so cutting slits in it would probably require an intermediate piece to bridge the gap, or much easier would be a custom made reducer sleeve which is about £10 on ebay and made to your dimensions.
Offline J12spk
  • VW PERVERT
« Reply #5 on: November 11, 2013, 04:45:23 pm »
You mean extend the existing hidden pipes jay?
Thanks for your other comments guys
Das Auto
Offline xjay1337
  • -Receive: 377
« Reply #6 on: November 11, 2013, 05:05:18 pm »
Yes they can either chop off the exhaust from where the rear section joins onto the downpipe (so a cat back) or cut off the hidden pipes and weld on two new pipes.
Either option would be cheaper than putting a GTI exhaust on
GTI exhausts on TDIs are honestly such a big waste of time and money.
Offline J12spk
  • VW PERVERT
« Reply #7 on: November 11, 2013, 07:12:55 pm »
Cheers bud, it's purely just for looks so wana be cheap as poss! Will need a gti valance too!
Das Auto
