Author Topic: Multifunction steering wheel - change indicator stalk ?  (Read 1337 times)
Offline darrenchambers
« on: November 13, 2013, 05:38:36 pm »
Hi everyone,
So I just got myself a 2008 Gti on 50k in Grey. Previously had a Mk2, x2 Mk3 8v and lastly a Mk4 150bhp which was a terrific car.
Looked for ages for the right motor but never found one with the spec I wanted ( everything ) so I had to settle for less and now I'm trying to quickly spec up the car.
Needs MFSW, RNS510 ( got one, ready to go in ), MDI, Cruise control.
Thought the car should be pretty easy to retrofit stuff into since it's a later model and has a 'Q' canbus.
My question is:
When fitting the MFSW do I need to change the indicator stalk since the functions are duplicated and the manual suggests that the indicator stalk is different when the car is ordered with a MFSW ?
Thank you,
Darren
Offline doylebros
Re: Multifunction steering wheel - change indicator stalk ?
« Reply #1 on: November 13, 2013, 06:11:25 pm »
If your going to fit cruise your going to change the stalk anyway - you'll need to check your steering controller part number for it to work.
The man to contact is Eddie-NL - he does all you need at cracking price ( parts or Labour).
« Reply #2 on: November 13, 2013, 08:17:37 pm »
Cruise is on the left stalk though isn't it ?
& All of the MFD functions are accessed through the right stalk.
Or am I missing something ?
Offline Matto
  • -Receive: 116
« Reply #3 on: November 13, 2013, 08:44:57 pm »
This is correct but as doylebros said you need to check what steering controller you have fitted to make sure it supports cruise.
« Reply #4 on: November 13, 2013, 09:24:53 pm »
Cheers guys,
I have vcds so I'll see if I can find out what controller is installed over the weekend.
Still unsure if I will need to swap the indicator stalk over though ?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #5 on: November 13, 2013, 09:30:14 pm »
I never changed mine when i upgraded to a MFSW. The right stalk i mean
« Reply #6 on: November 13, 2013, 09:33:53 pm »
cool, so it can stay and still works - I think I'll do that, better to have more than one way to do things.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #7 on: November 13, 2013, 09:38:37 pm »
Yeah works fine. The rocker on the end of it still works to cycle through the menu too
