Author Topic: cdl engine problems  (Read 2443 times)
Offline betts
cdl engine problems
« on: November 14, 2013, 05:11:46 pm »
I currently own a prefacelift mk2 Leon cupra which I've just had to replace the engine due to a piston melting and scoring the bore anyway I've replaced the engine with a cdl engine from a golf r, everything's been fitted and it's running ok but when I come to a stop the revs will rise up to between 2-3k rpm and then slowly fall back to a normal idle, I've also had an engine management light pop on and the car has an intermittent missfire, it will be running fine and the then for a few seconds it will be like the cars running on 3 cylinders and then it's fine again. Any ideas guy because after spending 3k on the car I was expecting for everything to be fine
Offline EddieA
Re: cdl engine problems
« Reply #1 on: November 14, 2013, 05:14:47 pm »
have you checked the pcv?
Edition 30 TTE420 - number 470 - RTech 418bhp and 391lbft
Offline phem0r
« Reply #2 on: November 14, 2013, 05:23:58 pm »
+1 for this
MK5 Golf GTi - Revo Stage 1 - Forge TwinTake - Milltek Catback - Eibach Sportlines
Offline edd666999
  • -Receive: 89
« Reply #3 on: November 14, 2013, 05:29:08 pm »
Which map sensor did you use?
Offline betts
« Reply #4 on: November 14, 2013, 05:33:19 pm »
I just changed the block, I believe all the sensors havnt been changed
Offline edd666999
  • -Receive: 89
« Reply #5 on: November 14, 2013, 05:46:15 pm »
Do some forum searching, I remember something similar with a cdl engine and it was that a different sensor was needed depending on ECU.
Offline betts
« Reply #6 on: November 14, 2013, 05:47:15 pm »
Sorry to sound dumb but what's the pcv?
Offline betts
« Reply #7 on: November 14, 2013, 05:50:18 pm »
Sorry to be a pain but have you got any idea what sensor will need changing?
Offline mdmay
  • -Given: 38
« Reply #8 on: November 14, 2013, 05:52:15 pm »
can you get a vag com scan done. where are you in the country?
Regards,
Mike
Offline betts
« Reply #9 on: November 14, 2013, 06:00:46 pm »
Nottingham mate
Offline edd666999
  • -Receive: 89
« Reply #10 on: November 14, 2013, 08:01:32 pm »
From memory I'd guess the map sensor...but I maybe wrong.
Offline martziniuk
« Reply #11 on: November 14, 2013, 08:06:59 pm »
Yeah it's the map sensor but you only need to change that if upgrading from a car that previously had a K03, the Cupra has a K04 as standard so should have the 3 bar (I think it is) map sensor.
« Last Edit: November 14, 2013, 08:09:10 pm by martziniuk »
Offline betts
« Reply #12 on: November 14, 2013, 10:40:47 pm »
The golf had a dsg gearbox if that helps. I thought with the cars revs rising after coming to a stop it may be fuel pump related but I havnt got a clue, I'm at the end of my tether  :sick:
« Reply #13 on: November 15, 2013, 12:03:19 am »
Yep, needs logging to determine the fault. There are quite a few faults that could do similar to what you are describing, including the runner flap position fault or throttle body fault to name a few. Unless it is logged and you get a code to work from you could just end up doing needless work. :smiley:
Offline john87
  • -Receive: 53
« Reply #14 on: November 15, 2013, 09:55:27 am »
The PCV is the Positive Crankcase Ventilation valve.. it controls the amount of vacuum present in the crankcase, in other words it's a more sophisticated system than cars which simply feature a breather pipe which links into the air intake pipe.
If your PCV fails, you may experience rough running amongst other symptoms.
