Author Topic: Help! Low oil pressure  (Read 2900 times)
Offline Roadrebel
« on: November 15, 2013, 01:28:00 pm »
I was driving home from work last night and after about 6 miles there was a momentary hesitation at about 60mph but only for a nano-second.
A few miles later the oil pressure light came on. I slowed down and it went out but it came on again twice more before I got home.
I checked the oil this morning and the level seems to be too high and there was a very small bit of mayo on the tip and lots on the filler cap.
There doesn't appear to be any oil in the water and the level is ok.
I am thinking the hesitation was the head gasket blowing and water is getting into the oil causing problems with the pump.
Where to start? 05 car 116k.
Any help appreciated  :confused:
Offline xjay1337
  • -Receive: 377
Offline Syrag64
Re: Help! Low oil pressure
« Reply #2 on: November 15, 2013, 02:07:25 pm »
Thats an interesting read, I think I may get my sump dropped and pick up checked........... prevention better than cure
Black 2007 GTI Manual, Stage 3 K04, R32 Bumper/Exhaust, WALK, adj rear ARB, KW1's, Twintercooler, Twintake, 18's (winters), 19's (summer) modified dectane LED rear lights, NQSBBK, Forge dump valve, Xenon look headlights with 5000k HID, 3" downpipe with sports cat, TT wishbones, uprated HPFP, Sach Uprated Clutch, Quaife LSD, VT & THS Engine Mounts.
To be fitted: Reverse Camera & uprated headunit.
Future plans: De-dent & Detail
Offline Roadrebel
« Reply #3 on: November 16, 2013, 12:50:39 am »
http://www.mk5golfgti.co.uk/forum/index.php/topic,68442.0.html
Thanks, I read that one and many others. Hopefully that is all that is wrong and a new pick-up pipe will do the trick. It was the tiny bit of mayo on the dip stick
that got my mind thinking and the high oil level but I may have over filled it when I changed the oil recently.
That's a great guide you posted, how long did it take to do the job?
Offline lee_plum
« Reply #4 on: November 16, 2013, 01:06:14 am »
Have you uprated your high pressure fuel pump?
Offline xjay1337
  • -Receive: 377
« Reply #5 on: November 16, 2013, 01:31:41 am »
All in about 2 and a half - 3 hours , a good chunk of that was cleaning the sump. and allowing a 30 minute dry time for the gasket sealant.
Slight mayo is not really an indication of anything especially on these engines.
A headgasket going should not in theory cause oil pressure problems , if the HG blew badly enough to cause low oil pressure it'd be eating through oil &/or coolant like nothing else.
Offline Roadrebel
« Reply #6 on: November 16, 2013, 08:33:26 am »
No, but reading up on it, it doesn't seem so much of a problem on the AXX engine.
Offline Roadrebel
« Reply #7 on: November 16, 2013, 08:38:36 am »
Good point, there is no sign of oil in the coolant either which, btw, appears to be plain water!
I think I will pull it apart tomorrow and have a look.
Offline Human Joist
« Reply #8 on: November 16, 2013, 09:01:43 am »
The mayo in the filler cap is normal from what I understand due to the deep filler hole. I have seen a few like it including mine
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #9 on: November 16, 2013, 09:23:04 am »
It's condensation. A good blast will clear it.
'07 Red manual
Offline Roadrebel
« Reply #10 on: November 17, 2013, 08:30:14 pm »
All done and better than ever thanks to the advice on here.
Been for 25 mile drive and no oil pressure problems, it seems to run better but that may be psychological!
An added bonus is that my emissions light has also gone off.
I checked my cam follower while I had the cover off and that was ok.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #11 on: November 17, 2013, 09:00:33 pm »
If the oil was overfull, it could have been topped up with fuel from a leaking HPFP. Worth checking that too - it has happened to folk before  :sad1:
