Author Topic: Retro Fit Cruise Control  (Read 1400 times)
Offline ahadmehmood
« on: November 16, 2013, 12:33:13 am »
Hi I was wondering if somebody can help I have tried to fit retro fit cruise control to my car however it is not working I keep getting a error E45 implausible signal intermittent. The guy who is doing it for me is sure he is coding it in correctly. I have attached my VCDS log if someone can have a look and help. My steering wheel module number is 1K0953549CH which is compatible and I have purchased a brand new cruise control kit from vw teeside.
Thursday,14,November,2013,19:01:49:51843
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: VSSZZZ1PZ6R086566   License Plate:
Mileage: 141030km-87631mi   Repair Order: MO's 2006 Seat Leon 2.0TDI
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56
VIN: VSSZZZ1PZ6R086566   Mileage: 141030km/87631miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 021 LL    HW: 03G 906 021 LL
   Component: R4 2,0L EDC G000SG  9185
   Revision: --H03---    Serial number: SEZ7Z0F3473219
   Coding: 0050072
   Shop #: WSC 12345 123 45678
   VCID: 74E187231771ACBE80B-8021
2 Faults Found:
001384 - Cruise Control Switch (E45)
               P0568 - 008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 141037 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:48:31
             Freeze Frame:
                    RPM: 798 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.21 V
                    Bin. Bits: 11001100
                    Bin. Bits: 00000000
                    (no units): 0.0
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 001 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 141037 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:48:31
             Freeze Frame:
                    RPM: 798 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.21 V
                    Bin. Bits: 11001100
                    Bin. Bits: 00000000
                    (no units): 0.0
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0000641
   Shop #: WSC 06441 785 00200
   VCID: 3F8B180F6EB73FE6AD9-806A
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No SW: 5P0 820 047 M    HW: 5P0 820 047 M
   Component: Climatic PQ35   014 0606
   Revision: 00014014    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 377B702F468707A6659-8062
2 Faults Found:
01296 - Sensor for Vent Temperature; Center (G191)
            007 - Short to Ground
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000003969246
   Coding: A1880F3F00041000001D00000000000000007F075C
   Shop #: WSC 00008 210 45725
   VCID: 2B535C5F8ACFB346111-807E
   Subsystem 1 - Part No: 1P0 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SE350  012  0403
   Coding: 00056272
   Shop #: WSC 00008
2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 6
                    Mileage: 141037 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00979 - Lamp for Low Beam; Right (M31)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 6
                    Mileage: 141037 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 3C0-909-605.lbl
   Part No SW: 3C0 909 605 L    HW: 3C0 909 605 L
   Component: R4 AIRBAG VW8   030 2522
   Revision: 12030000    Serial number: 003B0PDCNUPD
   Coding: 0021044
   Shop #: WSC 04941 785 00200
   VCID: 2F6B484FBED7CF663D9-807A
   Subsystem 1 - Serial number: 6332MSME0E405F49
   Subsystem 2 - Serial number: 6342MSME0E340A72
   Subsystem 3 - Serial number: 6351HTS64IKMM563
   Subsystem 4 - Serial number: 6361HTS63IKAIAT2
   Subsystem 5 - Serial number: 00000000000000000
   Subsystem 6 - Serial number: 00000000000000000
1 Fault Found:
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
            001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Component: J0527           056 0111
   Coding: 0000534
   Shop #: WSC 12345 123 12345
   VCID: 7AFDA91B3515DACEDA7-802F
   Subsystem 1 - Part No: 1P0 959 538 B
   Component: E221__MFL-TAP   H01 0100
   Coding: 00000226
   Shop #: WSC 00000
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1P0 920 941 A
   Component: KOMBIINSTRUMENT VO3 0724
   Coding: 0002401
   Shop #: WSC 00046 476 88215
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
            004 - No Signal/Communication
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 280010630681B3
   Coding: 7D0F0348072203
   VCID: 2A5D595B8535AA4EEA7-807F
1 Fault Found:
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 62
                    Reset counter: 6
                    Mileage: 140726 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:27:36
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VO3 0724
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 B
   Component: RNS-MID       H11 1300
   Revision: AB001001    Serial number: VWZ6Z7J8273164
   Coding: 04000400040000120020
   Shop #: WSC 00020 790 12345
   VCID: 2E55554B79DDC66E36F-807B
2 Faults Found:
03138 - Input AUX IN
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 140726 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:27:51
01299 - Diagnostic Interface for Data Bus (J533)
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 252
                    Mileage: 140726 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:27:52
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2352
   Coding: 0000688
   VCID: 36657D2B418DFEAE7EF-8063
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 3461472357F1ECBE40B-8061
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            000 - -
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 19C000BC09000505485B863004CC
   VCID: 79FFB6173013D1D6D3D-802C
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE No Answer
2 Faults Found:
01135 - Interior Monitoring Sensors
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1T0 959 702 B
   Coding: 0000688
Address 55: Xenon Range
Cannot be reached
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 140726 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:27:51
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 252
                    Mileage: 140726 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:27:52
End   ---------------------------------------------------------------------
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #1 on: November 16, 2013, 12:36:11 am »
A lot of modules in that log are showing communication issues...
Has everything been reconnected properly?
Jas
VCDS (Preston, Lancashire)
Offline ahadmehmood
Re: Retro Fit Cruise Control
« Reply #2 on: November 18, 2013, 01:06:35 am »
yes jas as far as I know everything is put back in correctly I have also tried two different stalks
Offline Scousus maximus
« Reply #3 on: November 18, 2013, 11:08:23 am »
Hi,
I think Eddie-NL is your best bet, he'll probably be along soon.
Regards,
John
