Author Topic: HELP PLEASE - RNS510 maps problem  (Read 5775 times)
Offline Pricey67
Re: Re: HELP PLEASE - RNS510 maps problem
« Reply #15 on: November 17, 2013, 04:37:23 pm »
You could upgrade to 4xxx fw and import pois through sd card.
Sent from my GT-I9300 using Tapatalk 2
Raz, other than the obvious are there any benefits for upgrading to 4xxx fw?
Steve
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #16 on: November 17, 2013, 05:04:37 pm »
Not too sure buddy
 I think its slightly more responsive.  Startup time might be improved too.
Offline SkyJawa
« Reply #17 on: November 17, 2013, 05:24:22 pm »
Does that one work with the battery drain fix though?
Also others seem to say if you remove the poi's they become greyed out on the nav and you can't re add via SD.......?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #18 on: November 17, 2013, 06:27:36 pm »
I've not seen 4xxx work with battery drain fix.
Offline SkyJawa
« Reply #19 on: November 17, 2013, 07:10:34 pm »
Damn!  I thought that was the case.
Have to hunt ebay for an official disk
