Author Topic: DAB Aerial  (Read 7725 times)
Offline andybon
Re: DAB Aerial
« Reply #15 on: January 31, 2014, 11:11:52 am »
I have just used the exact one in your first link and it works great. Just had to swap the connectors off the leads for my old ones and it works a treat!
How hard can it be?
Offline darrenchambers
Re: DAB Aerial
« Reply #16 on: January 31, 2014, 11:43:36 am »
 :happy2: cool, so I didn't need to go to the trouble of fitting a new roof mounted aerial then :grin:
Anyway, to follow up - the aerial I fitted is absolutely wicked, I always get a brilliant signal for both DAB and GPS.
For anyone wanting to do this conversion, this is what I did:
Obtained 6R0035501D & associated Polo aerial - left the bung in screw hole and took it straight to a paint shop with my colour code cost me £50 to paint, adds up but really looks factory fit.
I needed to run x2 6m female to female fakra connectors - I got them from here:
http://www.ebay.de/itm/Antennen-Verlaengerung-FAKRA-Winkelbuchse-Buchse-6m-TYP-Z-Antennenkabel-GPS-/110918256400?ssPageName=ADME:L:OU:GB:3160
They took about a week to arrive.
I then bound them together with fabric tape every 2 inches ( took ages ).
Next I removed the plastic trim that runs across the roof & undid the C-Pillars at the top. Also unscrewed the grab handles in the back.
My car is a 4 door car and I found that it is a lot easier to complete this work if you take off the 2 b-pillar trims as well, this allows the roof lining to come down a bit further and stops it creasing above the B-Pillar - it's really easy but make sure you use a magnetic screwdriver or waste an hour finding your screws like I did !
Next I removed the front nearside ( passenger side ) grab handle, removed the A-pillar trim and fed the fakra cables across the roof lining, it was awkward but it worked really well. I might also have loosened the sun visor too.
Buttoned it all up and I'm dead chuffed !
This weekend I got my new MFSW to fit :)
Cheers!
Offline pjuster
Re: DAB Aerial
« Reply #17 on: December 19, 2014, 04:08:31 pm »
thanks for the description of how you ran the cables that has really helped me.
Can I ask why you only bought 2 extra cables, from looking at that aerial there are 4 cables/connections.  I presume you used the existing FM cable and then the 2 extra were for DAB and GPS, whats the fourth for and why didn't you use it ?
is there any documentation on the aerial and what the connections are all for, I assume FM, DAB, GPS and phone ? but would like to confirm this.
Sorry just wanting to get this right in my head before I go ahead.
thanks in advance.
Offline paulw123
  • -Receive: 47
Re: DAB Aerial
« Reply #18 on: December 19, 2014, 04:44:22 pm »
reply 7 explains all, take it he didn't want to use the phone functionality.
this is where a lot of guys have got their DAB aerial
http://www.ebay.co.uk/itm/NEU-Original-Antenne-6R0035501D-Golf-VW-SKODA-Radio-Telefon-GPS-Neuuuu-/271685146748?
becareful of the newer polo aerial as it will not pass through the roof hole.
Re: DAB Aerial
« Reply #19 on: December 19, 2014, 06:57:38 pm »
That's right, I didn't use the 4th cable for the phone cradle, nowadays that's defunct. Instead I installed the Skoda phone module under the drivers seat and connected via bluetooth and the head unit.
Be extra careful if you run the cables across the roof, it's easy to bend the roof lining in the middle so I'd definitely remove the centre pillars.
When you're half way through it looks a right mess but just brave it out and press on, it's really not all that bad; take your time.
What I would say is that if you think the aerial would look better painted ( it almost certainly will ) then get it done up front - you won't want to have to take it out again once it's in.
Cheers,
Daz
« Last Edit: December 19, 2014, 07:06:49 pm by darrenchambers »
Offline paulw123
  • -Receive: 47
Re: DAB Aerial
« Reply #20 on: December 20, 2014, 10:59:55 am »
I ran mine same way as Darren and had the same fun  :signLOL:
I just loosened the top of B & C pillars at the top and pulled them forward to tuck cable behind. I didn't touch the grab handles, just tucked cable behind upper roof lining edges. Worst bit was getting FM connector out to swap over, a mirror is a good idea, as you cant see what you are doing!!
I had to get someone else to hold new aerial on roof whilst fitting nut underneath.
Offline Cossie Killer
Re: DAB Aerial
« Reply #21 on: December 24, 2014, 03:49:37 pm »
Im not a fan of shark fin aerials, are the window dab aerials up to the job?!
Offline Golf_GT_TDI
  • -Given: 45
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
Re: DAB Aerial
« Reply #22 on: December 25, 2014, 01:20:37 am »
How about the Polo one?.. it looks the same as the stock Golf aerial but there is a DAB version  :happy2:
Re: DAB Aerial
« Reply #23 on: December 25, 2014, 02:00:20 pm »
Hmmm, is it this one:
http://m.ebay.com/itm/141515832291?_mwBanner=1
If so, looks much better  :happy2:
Offline Golf_GT_TDI
  • -Given: 45
Re: DAB Aerial
« Reply #24 on: December 25, 2014, 02:27:43 pm »
Yep get the genuine one mate, part number: 6R0 035 501 A  :happy2:
I was hoping to fit the 2015 model year Polo's aerial to my Mk5 but as discussed in the topic I'll link to below it has a different fitment, I'm still tempted to go ahead though.
http://www.mk5golfgti.co.uk/forum/index.php/topic,84892.45.html
« Last Edit: December 25, 2014, 02:32:48 pm by Golf_GT_TDI »
Re: DAB Aerial
« Reply #25 on: December 25, 2014, 03:30:03 pm »
Nice one, that looks ace and just what i need! :happy2: thanks for the part number!
Think the 2015 version maybe alittle too involved for my use but I'd imagine a competent bodyshop could fit cheap enough if you're not feeling brave.
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
Re: DAB Aerial
« Reply #26 on: January 08, 2015, 05:31:52 pm »
I've just fitted a Calero OEM one, same fitment as the golf. 2 seconds to fit and has both water seals as the OE one.
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline AndrewWillis
Re: DAB Aerial
« Reply #27 on: January 20, 2015, 09:19:26 pm »
if you're after complete OEM hidden away, I used the MK6 Tailgate DAB unit and just threaded it through the boot and headliner. Kufatec sell a complete set for it.
http://www.kufatec.co.uk/shop/en/DAB-/-DAB-Tuner/Retrofit-kit-DAB-/-DAB-antenna-module
05, 3door Red GTI DSG, BCS Powervalve 200 Cell, DNX525DAB, Xenons, R-Tech 2+
