Author Topic: Water in rear light  (Read 4027 times)
Offline chris s
Water in rear light
« on: November 17, 2013, 08:56:15 pm »
Has anyone else suffered with water ingress in the rear light unit? I seem to be getting quite a bit on, but having taken the unit off the car and bulbs out of the unit I cannot see anyway of getting further into the unit to dry it out.  Has anyone worked this out or if it's possible?
Candy White Edition 30 DSG
Revo Stage 2+
ITG, BCS TBE, Autotech HPFP
WALK
R32 Brake upgrade
S3 IC upgrade
Offline G40will
Re: Water in rear light
« Reply #1 on: November 17, 2013, 09:13:12 pm »
I also have some condensation in one of my outer lights, as have many others on here...
I've not tried it myself yet but a few people have just taken the light right out and dried it either in the airing cupboard or with a hair dryer and them clean the seals up and refit it nice and tight.
Offline xjay1337
  • -Receive: 377
« Reply #2 on: November 17, 2013, 09:15:45 pm »
As above you can do that, but ultimately it's a common problem and due to the seals perishing.
R32 lights don't do it.
Offline G40will
« Reply #3 on: November 17, 2013, 09:21:13 pm »
Really? How come? Revised seals?
Offline xjay1337
  • -Receive: 377
« Reply #4 on: November 17, 2013, 09:28:38 pm »
No idea but I've not heard of them doing it.
Offline winrya
« Reply #5 on: November 17, 2013, 09:39:56 pm »
I replaced 2 ed30 lights as the seals went and filled with water. These are the same as r32 lights so happens to them all
Offline chris s
« Reply #6 on: November 17, 2013, 09:43:46 pm »
Good to hear I'm not alone but odd it's so common tho... Might get the missus hair dryer involved
Revo Stage 2+
WALK
R32 Brake upgrade
S3 IC upgrade
« Reply #7 on: November 17, 2013, 09:49:10 pm »
my ed30 lights were doing it all the time so i took the out and if you look where edge of the light where it goes to the back quater you can see gaps where moisture gets in so i ran abit of super glue down mine and it sorted it
Offline chris s
« Reply #8 on: November 17, 2013, 09:52:13 pm »
Cheers mate, so you mean the opposite side to the boot?
Revo Stage 2+
WALK
R32 Brake upgrade
S3 IC upgrade
« Reply #9 on: November 17, 2013, 09:55:36 pm »
take the light out and you will where the gap is
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #10 on: November 17, 2013, 09:56:46 pm »
I had it in one cluster so replaced via Ebay, think it was £15?  Not even worth faffng with.  R32/Ed.30 lenses would be worth the hassle though.
Offline skard
  • -Receive: 245
« Reply #11 on: November 17, 2013, 10:07:07 pm »
Happened to my ED30 ones.
Try shake out as much water as possible, a few mins with a warm hairdryer, then left over a radiator overnight with some 10g silica gel pads inside too, then a bead of silicon once totally dried sorted it completely.
(If doing that cover up the hole left on the rear quarter panel if your car isn't garaged)
Offline chris s
« Reply #12 on: November 17, 2013, 10:10:06 pm »
I'll take it off again and look for the gap u mentioned, I couldn't obviously see it yesterday
Revo Stage 2+
WALK
R32 Brake upgrade
S3 IC upgrade
« Reply #13 on: November 17, 2013, 10:15:37 pm »
where the edge of the outer light needs the back quarter look down the inside of that--been trying to find a pic but nt come a cross one
Offline xjay1337
  • -Receive: 377
« Reply #14 on: November 18, 2013, 12:55:33 am »
What can happen is the seal does perish over time so your best bet is actually using a bit of black silicone sealant! but taking the lights off does help for access and cleaning before hand.
They need to be as dry as possible inside anyway so what a silica bag or put them in your airing cupboard over night.
