Author Topic: Steering Rack help!! All mk5's similar??  (Read 7268 times)
Offline AlexR
« on: November 18, 2013, 10:31:27 am »
So, my steering rack needs replacing. I just put my car up for sale and then this issue arose...nightmare.
A local breaker has a rack but but not from a gti. Are all steering racks got mk5's the same? Part number from VW is 1K2423055K. Any help much appreciated!
Offline xjay1337
  • -Receive: 377
Re: Steering Rack help!! All mk5's similar??
« Reply #1 on: November 18, 2013, 10:41:24 am »
May be different revisions but all are the same in terms of lock to lock turns.
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #2 on: November 18, 2013, 12:49:56 pm »
Different revisions try and get one off a late mk5 or a mk6
Offline AlexR
« Reply #3 on: November 18, 2013, 01:39:56 pm »
I'm not too fussed which rev it is, I just want it to fit and function. I am selling the car. Any ideas folks as I'm really stuck.
Offline xjay1337
  • -Receive: 377
« Reply #4 on: November 18, 2013, 02:41:05 pm »
Then get a cheap one from a scrappy or something, as long as it all works it should be fine.
early ones do suffer from a cracking noise on left lock however this does not effect the steering and is not a safety/wear issue.
Offline AlexR
« Reply #5 on: November 18, 2013, 03:56:06 pm »
A local scrappy has one from a 1.6 mk5 golf, is that going to fit/function? Every breaker I call says they can't confirm the racks they have are going to fit as they don't match the part no I'm providing. That part no is the latest rev so chances are they will be hard to come across. If I can get a prev rev that works I'll be happy.
Offline xjay1337
  • -Receive: 377
« Reply #6 on: November 18, 2013, 04:18:32 pm »
They are all the same turns lock to lock you may need to reprogram the steering ECU coding but should work.
Offline AlexR
« Reply #7 on: November 18, 2013, 04:23:46 pm »
Managed to get hold of one from a breaker. Came off a 2006 GTI so fingers crossed all is good. Cheers for the help folks.
Offline doylebros
  • -Receive: 310
« Reply #8 on: November 20, 2013, 05:26:31 pm »
Just noticed your post so looked it up on ETKA
1K2 423 055 KX is the current version offered from TPS as an exchange unit PRICE £910.13 full retail inc vat
This supersedes the following core part numbers
1K2 423 055
1K2 423 055 B
1K2 423 055 C
1K2 423 055 D
1K2 423 055 E
1K2 423 055 F
1K2 423 055 G
1K2 423 055 H
1K2 423 055 J
1K2 423 055 K
They say you should also use when fitting 1K2 423 055 K
1 x 1K2 972 111 AJ - wiring for servotronic £71.95
1 x 1K0 498 970 A  - repair set for steering box
I've never changed a MKV steering rack so can't offer any help on that front.
