Author Topic: RCD300 to RCD510  (Read 1263 times)
Offline jbenekeorr
RCD300 to RCD510
« on: November 18, 2013, 10:04:02 pm »
Hi all, firstly I'd like to apologise for yet another question of this type on here!
I've tried to read up as best I can but I'd like to confirm a few things.
I have a 2008 MK5 GTI with an RCD300 and iPod Dock thing in the armrest.
I want to fit an RCD510 DAB (ideally).
Am I correct in thinking that I should NOT require a new gateway due to the age of my car?
Will I require anything else? I think I need a new aerial if I go for a DAB one?
Will my iPod connection still work with an RCD510?
I hope you can appreciate that I've tried to do my homework and not just expect you all to tell me everything! Thanks!!!
Re: RCD300 to RCD510
« Reply #1 on: November 19, 2013, 08:44:36 am »
You should ideally get a vcds scan and it will tell you your canbus version.
Your ipod connection should still work but you may have to move one or two wires in the block harness that plugs into the back of the unit to correctly earth it.
Offline john87
  • -Receive: 53
« Reply #2 on: November 19, 2013, 09:47:57 am »
Your should be just fine with your 2008.
I fitted an RCD510 to my 08 plate, plug and play, no problems whatsoever with battery drain  :happy2:
Offline jbenekeorr
« Reply #3 on: November 19, 2013, 01:23:52 pm »
Thanks both. I think if I do get one I could fit it at the start of the weekend and leave the car to see if the battery drains.
Offline Adam-golf
  • Derv!
« Reply #4 on: November 20, 2013, 09:56:17 am »
I'm pretty sure it's golf's on and after 2007 that don't need to be modified for battery drain
Offline jbenekeorr
« Reply #5 on: November 20, 2013, 10:39:49 am »
I've ordered an RCD510 DAB, a glass mount DAB aerial and MK6 climate panel. Need a fascia I suppose!
Offline paulw123
  • -Receive: 47
« Reply #6 on: November 23, 2013, 10:58:46 am »
