Author Topic: Uprated Dogbone mount  (Read 4327 times)
Offline Syrag64
« on: November 19, 2013, 07:27:51 pm »
Does anyone make an uprated dogbone mount?  I'm going to get some THS engine mounts and want to do dogbone too if I can  :happy2:
Black 2007 GTI Manual, Stage 3 K04, R32 Bumper/Exhaust, WALK, adj rear ARB, KW1's, Twintercooler, Twintake, 18's (winters), 19's (summer) modified dectane LED rear lights, NQSBBK, Forge dump valve, Xenon look headlights with 5000k HID, 3" downpipe with sports cat, TT wishbones, uprated HPFP, Sach Uprated Clutch, Quaife LSD, VT & THS Engine Mounts.
To be fitted: Reverse Camera & uprated headunit.
Future plans: De-dent & Detail
  • -Receive: 427
Re: Uprated Dogbone mount
« Reply #1 on: November 19, 2013, 07:30:17 pm »
The Bush? Vibra-Technics.....
~~ Clicky here ~~
Offline Lewis86
« Reply #2 on: November 19, 2013, 11:57:22 pm »
noticed any difference if youve had it done?
Offline Syrag64
« Reply #3 on: November 21, 2013, 08:22:04 pm »
~~ Clicky here ~~
Nice 1 cheers  :happy2:
Offline BlackMk5Gti
  • ~DSG LYFE~
« Reply #4 on: November 21, 2013, 08:38:26 pm »
Hi Guys,
I'm also thinking of doing this mod....is it worth it on a DSG car??
« Reply #5 on: November 22, 2013, 12:06:05 pm »
There are several companies that will do an Uprated insert.
HPA do a complete replacement mount as do THS and a few others.
The HPA one costs quite a bit, but from the reports in the USA, it is the one to go for.
Offline Syrag64
« Reply #6 on: November 22, 2013, 10:59:53 pm »
Do they also do the engine mounts?  Where would I get them?
Offline LVS Racing
« Reply #7 on: November 25, 2013, 03:45:51 pm »
We keep the Revo Pendulam Mount (ie Dogbone) in stock
Please PM me for prices
Offline Homer
« Reply #8 on: November 25, 2013, 11:48:47 pm »
What is the purpose of this mod?
Offline vRSAlex
  • -Receive: 253
« Reply #9 on: November 26, 2013, 08:02:12 am »
I've used nearly all the different option of lower mounts over the years bar the hpa version.  There is no need to change the arm for something different. The inserts from powerflex and superpro work well if on a budget. The THS is a little harsh, but a good step up from an insert.  The one to go for if money is no object and you want the best qua lity and performance is the vibratechnics. They do the replacement bush for the subframe and the replacement small bush in the arm.
The bsh/revo kit is a full replacement arm, but with only an insert for the subframe. As you ddon't need to replace the arm it's not even worth a look in.
Follow AKS tuning on Facebook
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #10 on: November 27, 2013, 12:52:41 pm »
i have the THS mount and then bought the vibratechnics dogbone from alex.
it has settled down now a bit but the first couple of 1000 miles is like being in a diesel truck ( i would imagine!)
the NVH through the dash is severe and needed to take some of the dash apart to get rid of the rattles so if you're not prepared fot this dont bother.
if however, you want to make your car as hardcore as you can go for it  :party:
Offline vRSAlex
  • -Receive: 253
« Reply #11 on: November 27, 2013, 01:24:28 pm »
Turns out the THS mixed with the small VT bush in the dogbone isn't the best combo.
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #12 on: November 28, 2013, 11:20:18 pm »
why is that alex, cause the THS is too harsh?
Offline vRSAlex
  • -Receive: 253
« Reply #13 on: November 29, 2013, 01:20:10 pm »
I believe so Andy.
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #14 on: November 29, 2013, 10:29:36 pm »
I believe so Andy.
Aren't the VWR mounts harsher than THS or did i dream that? On well my fillings have just about recovered now  :grin:
