Author Topic: cruise controll  (Read 3378 times)
Offline faheem
cruise controll
« on: September 14, 2009, 10:16:03 am »
right this is a really stupid question so apoligies before i ask but you know the cruise controll stick, does that only work if the steering wheel is multi functional?
i have the option on the stick and the switches for on and off but it does not do a thing?! i know this sounds dumb but i really am getting to the point where im gona lose patience with the dealer, still need to get a tyre changed as its ripped!, fog light replaced as it does not work?! and i have just discovered there is a crack in the front spoiler just below the reg place which i think may have been glued or something, i am not a happy chappy?!  :sad1:
Offline nc35
  • -Given: 40
Re: cruise controll
« Reply #1 on: September 14, 2009, 10:25:54 am »
Nope you don't need the MFSW
Someone will be along soon to correct me, but I think you need to get the car on a VCDS/VAG-COM to see if the CC has been coded to the car or is functioning correctly.
If its a faulty unit they are about £55 from the dealer, part only - still needs fitting.
No Golf anymore.
Enjoyed the last five years of ownership of Mk5 & 6 GTIs.
Plus an excellent forum for knowledge and new ways to deplete the bank account.
Thank You Everyone.
Offline nc35
  • -Given: 40
Re: cruise controll
« Reply #2 on: September 14, 2009, 10:28:06 am »
Oops should also have mentioned cc only works at speeds over 20mph ish and car needs to be in 4th (i think) or higher.  Will disengage if you touch the clutch or brakes.
Don't know if this helps
No Golf anymore.
Thank You Everyone.
Offline faheem
Re: cruise controll
« Reply #3 on: September 14, 2009, 10:30:14 am »
really? i didnt know that,im sure ive tried it in 4th, hope your right.....!
Offline faheem
Re: cruise controll
« Reply #4 on: September 14, 2009, 10:32:03 am »
is this like the diagnostics check thing? so im gona have to get it to a garage i guess, oh well, waiting for the local vg dealer to call back......
Offline Jules86
  • -Receive: 46
    • Forumwars
Re: cruise controll
« Reply #5 on: September 14, 2009, 10:35:46 am »
You switch it on and then press the minus speed button to set it.
Offline faheem
Re: cruise controll
« Reply #6 on: September 14, 2009, 10:39:08 am »
yeah ive done that, held the minus button for a few seconds, tried it by pushing it just the once, nothing happens, is cruise controll symbol meant to come on as soon as switch it to on? or is that only when you get the speed to set ?
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: cruise controll
« Reply #7 on: September 14, 2009, 11:11:35 am »
It's not gear dependant, above about 15mph/20kph is adequate to use it.
Is the car new or used?  Is it factory fit or retrofit? Have you read the manual on it's operation?
Some cars had a faulty CC stalk, there was a bad batch a couple of years ago.  Other thing to cause an effect is the brake pedal switch.
Stu...
Offline clive_gti
Re: cruise controll
« Reply #8 on: September 14, 2009, 12:03:02 pm »
The cruise control symbol should come on when you activate it by flipping the switch on top of the indicator stalk to on (i.e. before you set the speed)
Nasir
Re: cruise controll
« Reply #9 on: September 14, 2009, 12:08:38 pm »
If you're after a tyre, let me know Faheem
Offline faheem
Re: cruise controll
« Reply #10 on: September 14, 2009, 03:19:33 pm »
so seeing as i only got it like 2 days ago should i take it back to the dealer? or is it going to be outside the warranty? i am abit like a fish out of water with this stuff........it does not do anything at all, ive followed the instructions to the last detail but it just aint happening
nasir, the dealer is going to replace the tyre for me free of charge as we noticed it when picking the car up, shame i didnt notice the crack! lol its very hard to notice though......
Re: cruise controll
« Reply #11 on: September 14, 2009, 09:32:44 pm »
er i dont wanna steal the thread here, but i thought it pointless to start a new one for a quick question, to those in the know... They are selling the genuine cruise kit on ebay for just short of 50squids. Is this easy to fit, or should this be left to the pro's?
this is the kit... http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170361694017&ssPageName=STRK:MEWAX:IT
Offline QD MBE
  • -Receive: 102
Re: cruise controll
« Reply #12 on: September 14, 2009, 09:35:32 pm »
Looks the real deal to me.  The fit will include some coding via VCDS (aka Vagcom).  VRSTU is the best to ask, as there is some compatibility issues with the Controllers.
Re: cruise controll
« Reply #13 on: September 14, 2009, 09:38:33 pm »
oh and faheem, im sure the dealer will put it right. If they sold you a car with cruise control, you want it to work. its not too expensive if they have to fit you a new unit. Is it a VW dealership?
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: cruise controll
« Reply #14 on: September 15, 2009, 02:57:03 am »
Yep that's the fella you need.
As above, once installed it will need coding to suit the car.  You need to have the correct steering controller but if yours is an ED30 it should be ok.
Stu...
