Author Topic: MK6 Climate Control  (Read 9333 times)
Offline jbenekeorr
MK6 Climate Control
« on: November 20, 2013, 06:36:41 pm »
Hi all,
I'm getting an RCD510 so I decided to also get the MK6 climate control unit. I understand this should fit as mine has the AC button and is an 08.
I can't find a huge amount of info but I have ordered a fascia surround thing from a mk 6 from vw which hopefully should be correct.
Is there anything else I will need?
Offline doylebros
  • -Receive: 310
Re: MK6 Climate Control
« Reply #1 on: November 20, 2013, 07:25:21 pm »
VCDS as you have to do the adaption  - go to Ross tech
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Climatic
And have a look there but it's required if you want the system to run correctly.
Offline jbenekeorr
« Reply #2 on: November 20, 2013, 07:27:53 pm »
Thanks for the reply. I thought that was for older cars.
What will happen if I don't do that?
Offline doylebros
  • -Receive: 310
« Reply #3 on: November 20, 2013, 07:34:32 pm »
It tends not to work correctly - just do a bit digging on the rosstech site and it points you in the right direction!
Offline doylebros
  • -Receive: 310
« Reply #4 on: November 20, 2013, 07:39:18 pm »
This is what I was getting at
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(5K)_Climatic
I've not had the problem but I know failure to following this result in problems!
Offline jbenekeorr
« Reply #5 on: November 20, 2013, 07:49:49 pm »
Thank you!
I have found someone who can do it. Should I fit it and see what happens or just wait and fit it then get the reset done?
Offline doylebros
  • -Receive: 310
« Reply #6 on: November 20, 2013, 07:54:21 pm »
It's all easy really -  just that's what's needed to finish the job off correctly!
Come back and let's know how you got on but I don't know of any other issues.
Offline jbenekeorr
« Reply #7 on: November 20, 2013, 07:55:33 pm »
Great, Thanks for your help.
Offline doylebros
  • -Receive: 310
« Reply #8 on: November 20, 2013, 07:57:00 pm »
On the facia you'll need the Jetta MKV one not MKVI if I remember correctly!
MC71 has one fitted look at his build thread.
Offline jbenekeorr
« Reply #9 on: November 20, 2013, 08:01:51 pm »
Oh no! I've ordered a mk6 one from vw now!!
Offline doylebros
  • -Receive: 310
« Reply #10 on: November 20, 2013, 08:04:06 pm »
I'll do a bit checking on the part numbers when my machine has finished up dating and let you know what you should have ordered.
Offline jbenekeorr
« Reply #11 on: November 20, 2013, 08:40:22 pm »
I've found a part number on here: 1K0 858 069 M 1QB
That sound right?
No idea what I ordered, told him to go get the reg off the mk6 out the back my mate just bought and use that lol
Offline doylebros
  • -Receive: 310
« Reply #12 on: November 20, 2013, 09:00:21 pm »
That's an old number now which will fit but now it's :-
1k0 858 069 N 1QB. Price £ 32.66 full retail inc vat
That's the one you need to order if buying from anywhere
Offline jbenekeorr
« Reply #13 on: November 20, 2013, 09:02:49 pm »
Great - and do we know is that from a mk5 or 6?
Offline doylebros
  • -Receive: 310
« Reply #14 on: November 20, 2013, 09:08:13 pm »
https://www.google.co.uk/#q=1k0+858+069+N+1QB
Look at that image that's from a 2009 Jetta you need to make sure that matches the electronic panel you've ordered do you know that part number?
