Author Topic: MK6 Climate Control  (Read 6942 times)
Offline jbenekeorr
Re: MK6 Climate Control
« Reply #15 on: November 20, 2013, 09:10:56 pm »
No part number. It's this one though http://bit.ly/1bDCPhH
  • -Receive: 427
« Reply #16 on: November 20, 2013, 09:19:56 pm »
PM'd  :happy2:
EDIT: just seen I have a PM from you!  :signLOL:
Offline doylebros
« Reply #17 on: November 20, 2013, 09:21:34 pm »
That one requires the long slot on the top
Just make sure you don't buy
1k0 858 069 H. Or
1k0 858 069 K
They only have short slot in the centre
Offline jbenekeorr
« Reply #18 on: November 20, 2013, 09:23:11 pm »
Thanks thanks thanks all! I'll ring vw in the morning with that part number.
  • -Receive: 427
« Reply #19 on: November 20, 2013, 09:25:56 pm »
Incase anyone needs the PN, Its this one......
Not my car, generic pic from the interweb...
Offline doylebros
« Reply #20 on: November 20, 2013, 09:27:24 pm »
No problem - Ask MC71 if he can give you any pointers in advance! :happy2:
That's what I mean by pointers!
Offline doylebros
« Reply #21 on: November 20, 2013, 09:34:09 pm »
Finally, the part number of the panel you've ordered  - some can be to young to work - come back with the number off the back and we'll check it before you pull it all a part!
Offline jbenekeorr
« Reply #22 on: November 20, 2013, 09:40:33 pm »
OH NO not more potential problems!!! I'll put it in this thread as soon as I get it.
Offline jbenekeorr
« Reply #23 on: November 21, 2013, 10:51:14 am »
I had ordered the wrong fascia. They are getting me the correct one now at about £30
Offline jbenekeorr
« Reply #24 on: November 22, 2013, 01:13:11 pm »
No part number on the climate panel but it does have a date (03.07.09) and 01367 A1 K and 174 785-01
What do we think?
Offline jbenekeorr
« Reply #25 on: November 22, 2013, 05:10:08 pm »
I've put it all in. Works very nicely. Found a button combination online that resets the flaps. The AC still needs doing so I won't use that until Monday when I'm getting someone with VCDS to do the reset for me. The fans seem to cycle on and off which I'm told means the compressor wants initialising or something.
VERY happy overall, RCD510 looks lovely and the DAB works well with a glass mounted aerial which is quite discrete. Did the pin swap and the ipod connection in the arm rest is working too
  • -Receive: 427
« Reply #26 on: November 22, 2013, 05:30:58 pm »
Sweet, good job.  :happy2:
Offline doylebros
« Reply #27 on: November 22, 2013, 07:07:06 pm »
That's been a productive day then :happy2:
Offline jbenekeorr
« Reply #28 on: November 25, 2013, 08:46:14 pm »
Just had the VCDS stuff done by 'John A' on here who is a great guy!
All working now (apart from the iPod Dock which seems to keep trying to pause the music constantly  :sad1:
I've ordered a female 30 pin iPod to 3.5mm and an aux plug which connects the same way the iPod Dock does in the hope that one will solve my problem. The music streams perfectly it just seems that something is making it send a signal to pause constantly (although sometimes it will work for 20 mins or so without issue).
Overall very happy :D
Offline j8ekt
« Reply #29 on: November 25, 2013, 08:53:01 pm »
Did you do the wire swap as in the guide , also did you have a Econ or AC button
Thanks John
« Last Edit: November 25, 2013, 08:56:36 pm by j8ekt »
CW Edition 30
