Author Topic: strange power loss  (Read 1206 times)
Offline samiep
strange power loss
« on: November 20, 2013, 10:22:30 pm »
so iv got an 55 plate mk5 gti with 96 on the clock when i put my foot down it goes to about 3 -4 rpm and it sort of jumps / loses power/judder its hard to explain but only for a split second but its in every gear. then its fine and pulls all the way, could it be the clutch slipping? i have no idea what it is any help would be much appreciated!  no lights have come up on the dash.
Offline shizy01
Re: strange power loss
« Reply #1 on: November 21, 2013, 09:43:15 am »
Check the PCV & DV, most common faults! Also try getting a VCDS scan......
Offline samiep
« Reply #2 on: November 21, 2013, 05:16:45 pm »
iv had my dv changed, whats the pcv expensive?
Offline shizy01
« Reply #3 on: November 22, 2013, 04:27:26 pm »
naa PCV is cheap, its around £38 inc vat at VW
Offline samiep
« Reply #4 on: November 22, 2013, 06:25:53 pm »
sweet cheers will see if it fixes the prob
Offline bellios
« Reply #5 on: November 22, 2013, 06:44:45 pm »
Got the same thing atm.can you let me know if you find a fix?
Ive done pcv and dv with no joy (and sparks and coilpacks and cam follower) currently showing no faults when scanned...
Offline samiep
« Reply #6 on: November 22, 2013, 09:09:37 pm »
will do, I'm getting a pcv tomorrow! is yours mapped?
Offline samiep
Re: strange power loss MAF
« Reply #7 on: December 11, 2013, 06:06:44 pm »
mine is the Maf sensor anybody else had this happen ?
Offline Baz300
« Reply #8 on: December 12, 2013, 06:05:31 pm »
APR HPFP solved that issue for me
