Author Topic: hii *warning contains moaning*  (Read 1117 times)
Offline mrdelboy
« on: November 20, 2013, 11:30:16 pm »
Hi all sorry if I have posted my rant in the wrong section
having been a diesel owner over the past 3 years e46 330d I finally decided to stop poluting the roads with thick layers of black smog .
So about two months ago I brought a 2006 gti dsg had around 75k but was completley standered no leathers or nav   :sad1: ended up getting a good deal so the thinking was to do it up slowly and maybe play with it a little nothing major just a remap as stock is well ..... Stock lol
So after a week I took it to the stealers for a service , just my luck first night out and engine management light comes on and the car was not running as it should did a bit of research and was showing signs of dv problems, to my joy the dv was knackered ( thinking I got away with it on the cheap  :smiley:
So to my horror on the way out of the garage same thing a bit jumpy when I put my foot down and loss of power at about 60+ .
So I booked it into vw and today I got my results : new camshaft and high pressure fuel pump and they quoted me £1700  :scared:
Now I have a few options none include main dealer all would be through a specialist and wouldn't mind some friendly advice  :happy2:
I have seen a loba hpfp it says it increases performance ? If it does how much more then standered ? What other parts would I need with it ? Were can I get a camshaft from ? I don't mind spending a bit extra if it will increase performance , thanks for reading cheers
Offline edd666999
  • -Receive: 89
Re: hii *warning contains moaning*
« Reply #1 on: November 20, 2013, 11:44:06 pm »
A loba, APR, autotech ect.... Fuel pumps are there to be using in conjunction with a remap and other modifications, the provide a higher pressure of fuel needed for...more power.
With those things needing replacing was it a worn cam follower that caused the issue?
Where in the UK are you and we can point you in the direction of some friendly garages that wont rip you off.
« Reply #2 on: November 20, 2013, 11:45:34 pm »
Camshaft???  :surprised:
Are you sure they didn't say HPFP and Cam follower?
They would be around £160+vat for genuine VAG ones
Fitting.....about an hour £60???
Id send a pm to AKS-Alex on the forum for advice.  :wink:
Where abouts are you?
Offline mrdelboy
« Reply #3 on: November 21, 2013, 12:00:59 am »
Hi thanks for the reply Im based in north London , he's words were the tapets are wearing in the camshaft they apparently found bits in the hpfp causing it to fail so both need replacing , or something along those lines . he said it could be repairable but as there main dealer they have to change the parts he advised me to take it to a specialist as they might be able to repair it without replacing parts ? Thanks
Offline Jaywoo-GTI
  • -Given: 38
« Reply #4 on: November 21, 2013, 10:04:42 am »
I have got a low mileage revision b camshaft if you are struggling.
Offline mrdelboy
« Reply #5 on: November 21, 2013, 04:11:57 pm »
Yea I would mate is there a way to pm me ?
Offline Jaywoo-GTI
  • -Given: 38
« Reply #6 on: November 21, 2013, 04:36:08 pm »
I think you need over 10 posts to PM
Here is a pic of the part number on the cam to check against your car.
« Last Edit: November 21, 2013, 04:49:03 pm by Jaywoo-GTI »
Offline mrdelboy
« Reply #7 on: November 21, 2013, 05:20:01 pm »
Cheers mate will have the code by tomorrow , how much £ am I looking at ?
