Author Topic: S3 rear brake upgrade done!  (Read 17849 times)
Offline QD MBE
  • -Receive: 102
Re: S3 rear brake upgrade done!
« Reply #15 on: September 15, 2009, 06:30:59 pm »
A very large and golden tuppence there, QD!
I don't think that anyone is claiming that one brake setup beats all others. As you say: Lots of opinions and several combinations which work extremely well for different people and different uses.
Good job it wasn't the golden rivet..................................
Ps modding fever has struck the bike.................................. :evilgrin:  Exhaust, bits and bobs of carbon, and new levers en route................. :evilgrin:
« Reply #16 on: September 15, 2009, 10:14:34 pm »
You're right in what you say about the S3 set-up. Very cost effective and probably as much as anyone on road will ever need. Let's hope the brakes on the R20 are multi-pot and vented at the rear from the start. :party:
Offline tinto
  • Pirelli GTI
« Reply #17 on: September 19, 2009, 07:33:36 am »
Right when I thought the AP 6 pot BBK i just picked up was going to be enough you go and post this sh*t Hurdy  :wink:
Is this the full vented rear setup?
I'd like to have all my brakes sorted in one hit, but would rather buy an S3 kit in red.
... does that mean chasing down a Cupra R rear set?
I'd rather not get stuck into painting an S3 setup.
Excuse my ignorance on it - SEATs aren't sold here in Australia anymore, so this sort of upgrade will be coming from the UK for me.
« Last Edit: September 19, 2009, 07:49:26 am by tinto »
« Reply #18 on: September 19, 2009, 01:12:22 pm »
Hi Tinto,
Yes it is the full S3 set-up including the 310mm vented discs, carriers, calipers and pads :happy2:
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #19 on: September 19, 2009, 02:44:07 pm »
sorry to dissapoint you, after i read this tread, i've had a look at a danish leon cupra, it had r32 frontbrakes, (which i also has installed on my mk v), but the rear breakes was the same as the gti, so you need to locate r 32 or s3 rear brakes to get the 312mm vented discs, sorry mate. Just get them powdercoated red, that's what i plan to do  :happy2:
Over the top mod list ;o)
Offline tinto
  • Pirelli GTI
« Reply #20 on: September 20, 2009, 10:32:41 am »
No worries, thanks for the clarification.
So there isn't a cupra R (k1?) that uses the r32/s3 rears?
There are a few options I can pursue including getting a rear r32 set out if the USA (world impex or the autotech kit etc), as the Aussie dollar is fairing better against the usd than the pound right now.
... I may be back to harrass you for a parts list hurdy :)
Offline tinto
  • Pirelli GTI
« Reply #21 on: September 22, 2009, 01:30:46 pm »
Had this link bookmarked a while ago:
http://www.worldimpex.com//assets/partdocuments/DIY_Rear_310mm_R32-1.pdf
has a parts list for those interested in this mod.
« Reply #22 on: September 22, 2009, 04:42:26 pm »
I was under the impression the Cupra R had vented discs.  :confused:
Anyone know for sure?
The part number I have for the rear discs on a Cupra is 1K0 615 601M whereas the one in the above attachment is 1K0 615 601 N.
I had planned to add the Cupra R rears but would look a bit of a twit(sp) if they are the same as I already have.  :ashamed:
« Reply #23 on: September 22, 2009, 04:43:14 pm »
the r32 ones are 100% vented
« Reply #24 on: September 22, 2009, 04:45:48 pm »
And the N is defo a 310 x 22m vented disc 112 x 5
« Reply #25 on: September 22, 2009, 04:47:33 pm »
Sorry, should have put this in one post.
The M version Hedge, is the 286 mm 12mm thick solid disc you probably already have.
The N is the R32/Cupra/S3 one you want! ;)
« Reply #26 on: September 22, 2009, 04:54:41 pm »
So N is R32 and S3 only from what I can find and M is Cupra. So whichever way I go about this my painting skills are going to be needed.  :sad1:
« Reply #27 on: September 22, 2009, 04:58:59 pm »
Im not sure if Cupra got the 286mm solid disc or not, but the M is defo a 286mm solid disc
Offline VeeDubDan
« Reply #28 on: September 22, 2009, 05:02:43 pm »
Cupra has solid rear discs, or at least the one in my works car park certainly does!  :wink:
« Reply #29 on: September 22, 2009, 05:03:47 pm »
I found this courtesy of Awesome. http://www.awesome-gti.co.uk/product.php?xProd=13789&xSec=359
So painting required as well. Bummer.
