November 22, 2024, 11:58:08 am
All Things Mk5
Mk5 General Area
Need help temperature exceeding 90 degrees
Topic: Need help temperature exceeding 90 degrees (Read 888 times)
vag12
Always Involved
-Given: 4
-Receive: 3
November 24, 2013, 02:33:12 pm »
What could be the cause of the car temp going past 90, I just noticed that it went 3-4 bars up, I checked coolant it is still full what could it be? No warning signs have come up
xjay1337
Just look at my post count
-Given: 15
-Receive: 377
My Ride:
Re: Need help temperature exceeding 90 degrees
Reply #1 on:
November 24, 2013, 03:21:47 pm »
Thermostat stuck?
Check the coolant tank see that coolant is being pumped back into the bottle (coolant pump)
Click for build thread
Stage 2 GTI Purple Scene Queen
221bhp/365lbft TDI build
Detailing Guide
Wheel Fitment Guide
Itguy
Always Involved
-Given: 0
-Receive: 2
Reply #2 on:
November 24, 2013, 04:30:00 pm »
Could also be a faulty temp sensor in the block.
Does it seem to warm up quicker than before?
vag12
Always Involved
-Given: 4
-Receive: 3
Reply #3 on:
November 25, 2013, 01:48:02 am »
Alright will have a look tommorow, bit of a wierd thing if I switch my car off and back on again temp goes back to 90 and stays there and back to normal again more of a intermittent problem
Llew
Always Involved
-Given: 45
-Receive: 17
Reply #4 on:
November 26, 2013, 06:54:25 am »
You have an airlock -start the car when cold then undo cap and let it run for 5 mins( you can rev from time to time ) then replace cap --- don't try remove cap when engine is hot- just a reminder
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
All Things Mk5
Mk5 General Area
