Author Topic: First Peek at DM's K04+ tunning on my MKV...graphs inside...more to come  (Read 6419 times)
Offline Shorty
  • -Receive: 24
Re: First Peek at DM's K04+ tunning on my MKV...graphs inside...more to come
« Reply #15 on: December 03, 2013, 01:46:55 pm »
Yes! I know! Right?
Must be running big fuel pressure to run that type of power!
| Mk7 R |
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #16 on: December 04, 2013, 07:16:31 am »
I haven't had a look at his fuel data...I do know mine is set to run higher pressures from both pumps. I have seen that the F23T with stock K03 injectors gives more power than I had before the new tune...310 to 315ish WheelHP. So, he has 25 to 30WHP more, the addition of WMI, and the DM tune over my old 285 WheelHP.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #17 on: December 13, 2013, 08:20:51 pm »
I had to replace my coils as they were all going bad over the past week at 103k miles.
New graphs from yesterday...
Boost....
Fueling:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #18 on: December 13, 2013, 08:24:10 pm »
Yes! I know! Right?
I'm pretty sure his hpfp pressure is set at 130bar, as are all the K04+ tunes by DM, but since he has stock injectors and the F23T it may differ...AFAIK
My hpfp specified is 142.5bar.
« Last Edit: December 13, 2013, 08:26:21 pm by ROH ECHT »
« Reply #19 on: December 13, 2013, 11:10:30 pm »
What pressure release valve are you using, a 145bar one?
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #20 on: December 14, 2013, 08:19:24 am »
Yep...the RS4 fprv.
« Reply #21 on: December 14, 2013, 10:17:49 am »
Yep...the RS4 fprv.
I'm confused now as the RS4 one cracks at 136 bar but your graphs show rail pressure of over 140 bar at the top end.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #22 on: December 14, 2013, 08:02:21 pm »
You are correct. I am in the process of getting an answer myself.
The rail actually reached:
151.39
148.24
151.62
147.69
152.57
149.84 bar from 6500 to 6900rpm. I know DM set my rail pressure request at 142.5bar and he said the fprv would hold...so?
I'll get back with the answer when I get one  :happy2:
« Reply #23 on: December 14, 2013, 08:08:03 pm »
With that sort of rail pressure I would look very carefully at your cam follower as I suspect it's likely to now wear more quickly...
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #24 on: December 14, 2013, 08:14:20 pm »
I do check it every 5k miles already and have been replacing it every 10k  with it looking like this:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #25 on: December 14, 2013, 11:11:37 pm »
FPRV info:
It begins to crack anywhere from 136-144 bar
But just because it cracks doesn't mean it's going to dump all of the fuel.
The spring is only depressing like 5% at that point and there is a minimal difference.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #26 on: December 19, 2013, 06:01:28 am »
I replaced all 4 coils and it runs sooo good now....even better.  :happy2: Will have more when it dries up around here.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #27 on: December 21, 2013, 10:58:43 pm »
I now have the race fuel tune and I will have more to report along with a vid real soon  :happy2:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #28 on: January 04, 2014, 02:03:26 am »
New 0 to 120 mph vid of the DM K04+ Tune in 13.3 seconds:
Offline Eddie07
« Reply #29 on: January 04, 2014, 08:47:31 am »
Impressive numbers and nice vid.
