Author Topic: Poor radio signal - intermittent.  (Read 953 times)
Offline warby
« on: November 30, 2013, 09:55:38 pm »
I have intermittent poor signal in the edition, the gti signal was always rock solid. (It had a shark fin, the edition has a "normal aerial" with stubby thing screwed into it.
I have found the following codes on my snap on scanner for the radio.
What do I need to buy / do / have done?
Nick
Offline doylebros
Re: Poor radio signal - intermittent.
« Reply #1 on: November 30, 2013, 09:59:07 pm »
What radio is fitted at the moment?
Offline warby
« Reply #2 on: November 30, 2013, 10:08:42 pm »
Rcd300 I think. Looks like the rcd300 but with silver buttons, says mp3 above the cd slot and has an aux input. Can get pics if needed
It must've had an aftermarket head unit at some point as it has amp cables to the boot.
Offline doylebros
« Reply #3 on: November 30, 2013, 10:30:49 pm »
Well there's your answer - you'll need to trace out the cables to see what the last owner has done.
I would remove the head unit and see what's connected for the aerial - possibly cables chopped to suit an after market system rather than fakra.
Offline warby
« Reply #4 on: November 30, 2013, 11:13:18 pm »
Cheers mate. I'll get it pulled apart and take a looky-see in the week. Will report back, most likely with more daft questions :)
