Author Topic: Listen to the chain rattle and tell me what you think (link on page 2)  (Read 8897 times)
Offline candy turbo
Re: Listen to the chain rattle and tell me what you think (link on page 2)
« Reply #30 on: December 13, 2013, 09:43:56 pm »
Gti5 whst year was/is yours ?
Offline GTI5
« Reply #31 on: December 13, 2013, 09:46:55 pm »
59 plate (Still got it), have you bought one?
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline candy turbo
« Reply #32 on: December 13, 2013, 09:56:06 pm »
Yes mines an 11 plate was warned about the 2009 early 2010 cars was led to believe from mid 2010 the problem was sorted , not too worried mine sounds sweet as a nut but is it worth getting the latest tensioner fitted ?
Offline GTI5
« Reply #33 on: December 13, 2013, 10:02:14 pm »
11 plate should have one of the later revisions, if you start hearing what sounds like a slack chain/rattle in the future then you could have it inspected but I don't think you will need to pay for a new one to be put on.
Whats the mileage?
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline candy turbo
« Reply #34 on: December 13, 2013, 10:09:51 pm »
16k miles , read that clean oil may help and its had 3 oil changes already last owner was an enthusiast ( suffered ocd ! ) same as me lol so hopefully be ok
Offline Snoopy
  • -Given: 31
« Reply #35 on: December 13, 2013, 10:35:29 pm »
Just how common is this fault ? Surely if there had been lots of failures it would have become a re call ? Is it just a handfull of cars or what ?
As ive pointed out a gazillion times on the other forum VW dont like to admit they make mistakes.
If its a saftey related item they will eventually do a recall. It took them public humiliation and a death in Australia before they did with the dsg box.
The sad thing is the tensioner is NOT classed as a saftey related item because its only the ratchet that fails.  It only uses the ratchet when oil pressure is not present in the tensioner. Therefore the tension only fails after the car stands for a while turned off. Then when you start it the tension is slack due to the weak ratchet design. The chain jumps a few teeth. The oil pressure builds. The chain tentions with oil pressure. The ecu trys to keep the car running by playing with cam timing and in the process the engine makes metal on metal contact. Pistons meet valves and a number of other issues if your really unluckie.
VWgmbh know theres an issue its why when they see the engine code for mismatched timing they supply a new engine free of charge without argument.
What the issue then is which is the not nice part is VWuk and their dealers charge for fitting and could be 2k most have got this down to around 500 with so called good will HA! But thats still alot for something thats down to a badly designed weak weak part ie a design issue!
As for the question about what tensioner will be used to fix a car. ]tensioner supplied now HAS to be the latest one as the parts disc states in red to never use the old part even if in stock. In ither words they know there an issue too!
The way Im looking at it is if it was a mk5 I would have had to pay for a cambelt change after 4 years. Paying a specialist similar money to change the chain tensioner isnt too much of a hardship. Ill just have to get my ass into gear and get it done.
Ps I just read above the comment about frequent oil changes helping. This is untrue. Its the mechanical ratched the tensioner drops back onto when the car is turned off and oil pressure falls off. Its the ratchet part that fails nothing to do with oil or oil quality.
« Last Edit: December 13, 2013, 11:04:15 pm by Snoopy »
Offline candy turbo
« Reply #36 on: December 14, 2013, 03:00:43 am »
^^^^^^ great post , thanks
Id read about the follower being " gunked " in sludge in some engines that had failed surely this would nt help
Offline Snoopy
  • -Given: 31
« Reply #37 on: December 14, 2013, 10:04:47 am »
Different part different issue. Its the mecanical ratchet inside the tensioner that fails due to poor weak design if you physically see the tensioner and have any mechanical knowledge its easy to see why it fails its shocking peace of design imo. The current latest tensioner is far better but im still not a fan of this design.
Its just a shame I like the rest of the car so much. I plan to changing the tensioner every 3 to 4 years unless mine goes bang in that time if that happens the cars going and its the end of me and my family with Volkswagens after 25 years years in my case and even longer with other members of the family.
« Last Edit: December 14, 2013, 10:12:00 am by Snoopy »
Offline candy turbo
« Reply #38 on: December 14, 2013, 10:31:28 am »
Ok so its pot luck really then , got to be treated as a service item really then , i might get mine looked at at next service to check i have the latest version of the tensioner!
