Author Topic: Heating the car  (Read 887 times)
Offline Human Joist
Heating the car
« on: December 07, 2013, 12:58:15 pm »
What's the best way to warm up the inside of the car the fastest. I know you need the resurc button on but does the air con make it warm up any after or not.
Offline triggerh4ppy
Re:
« Reply #1 on: December 07, 2013, 02:41:18 pm »
Turn your heater on... Jokes!
Sent from my Nexus 4 using Tapatalk 4 Beta
Offline Human Joist
Re: Heating the car
« Reply #2 on: December 07, 2013, 03:03:46 pm »
Did expect that to be honest. Seems to take an age to get warm inside as well as temp gauge too. Replacing the two small thermostats this week. Just wondered if air con made it quicker
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
Re: Heating the car
« Reply #3 on: December 07, 2013, 05:05:49 pm »
It's normal for it to take an age to warm up! Haven't found anything which makes it warm up noticeably quicker. Also worth noting that when it's below a certain temp outside the air-con won't work anyway even if it's set to on. It's a self protection thing incase it gets frozen up. Think it's about 4 degrees, but I'm sure someone on here will correct me if I'm wrong!
Offline Itguy
Re: Heating the car
« Reply #4 on: December 07, 2013, 05:37:58 pm »
It depends on your perspective as to what is ages to warm up.
My engine is fully warm at 90c on the gauge within 10 minutes from stone cold in these ambient temps around 3c here.
Warm air out of the vents within 3 or 4 mins of running.
If your car is taking longer than this to warm up then you have thermostat problems.
Yes, the aircon disables at low air temp (can't remember exactly what temp) to prevent icing.
Offline Human Joist
Re: Heating the car
« Reply #5 on: December 07, 2013, 05:59:01 pm »
Cheers guys
Offline Itguy
Re: Heating the car
« Reply #6 on: December 07, 2013, 06:06:07 pm »
I presume you're read my thread if you're replacing the two small thermos
http://www.mk5golfgti.co.uk/forum/index.php/topic,75756.0.html
Offline Human Joist
Re: Heating the car
« Reply #7 on: December 07, 2013, 06:10:08 pm »
Ahh yes mate. It was your entry that got me on to it to be fair. I get to work 9 miles and it's still only 70 degrees. Once it's to temp it stays there so am thinking same as you two smaller thermostats.
Offline Itguy
Re: Heating the car
« Reply #8 on: December 07, 2013, 11:05:22 pm »
Yep, do it.
I presume you have a 2005 DSG then if you have both?
Offline Human Joist
Re: Heating the car
« Reply #9 on: December 08, 2013, 01:21:40 am »
That's the one
Offline dmac1969
  • -Receive: 21
Re: Heating the car
« Reply #10 on: December 08, 2013, 08:41:00 pm »
Mine is the same as this , in fact both my GTIs have been. IIRC the Air Con doesnt function below 5C.
