Author Topic: Fitting rear door quarter glass on 5dr?  (Read 4725 times)
Offline Itguy
« on: December 08, 2013, 09:12:10 am »
Hi all
Anyone know how to do this? Is it easy?
For some reason my passenger side rear door has a green glass panel in it when the rest of the car has blue glass (as it should).
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Re: Fitting rear door quarter glass on 5dr?
« Reply #1 on: December 08, 2013, 09:25:39 am »
Early mk5 had blue tint later changed to green, most likely yours had been smashed and replaced.
I've never done it on the rear (have a 3 door)... There's a how to somewhere....
http://www.myturbodiesel.com/1000q/a5/door-skin-jetta-remove.htm
http://www.golfgtiforum.co.uk/index.php?topic=167499.0
Offline Leigh200sx
« Reply #2 on: December 08, 2013, 10:09:08 am »
It's quite easy to do but you have to partly remove the outer skin due to there being a torx screw  whind it that you need to remove to allow the window guide bar to be removed. Once the metal bar is moved it's just a case of slotting the rear vent in
