Author Topic: Ko4 turbo supply and fitting prices ?  (Read 3316 times)
Re: Ko4 turbo supply and fitting prices ?
« Reply #15 on: December 10, 2013, 10:48:08 am »
One arm holding the turbo and the other on the shaft  :wink:.
 :surprised:  :confused:
Alternatively take it to APR and it will be 6 months at least.  :popcornsoda:
Offline mdmay
  • -Given: 38
« Reply #16 on: December 10, 2013, 08:33:05 pm »
LMAO
Regards,
Mike
Offline Banham
  • GTI MK6
« Reply #17 on: December 10, 2013, 10:03:15 pm »
Alex how much would it cost to supply and fit just out of curiosity? Plans for 2014  :evilgrin:
Offline jamiep91
« Reply #18 on: December 13, 2013, 10:52:39 am »
Jabbasport will do the labour 230 for me does that seem ok
Offline GLIDN
« Reply #19 on: December 15, 2013, 07:37:15 am »
I thought its 5-6hrs labour
Id say that the realistic maximum.
On a ramp removing the exhaust and turbo is easy.  No more than an hour IMO.  Installing the DV relocation/DV/cable and new IC/TB pipe is fiddly but id imagine an hour would be sufficient.  Injectors a little more fiddly maybe 1-2 hours.
Come down and prove it Sy. I will pay you 100 quid an hour if you can do a turbo swap in an hour.
It's around 4 to swap the turbo, 3 for injectors inc cleaning the intakes and another couple fitting all the other bits and bobs.  Then you have to hope that it all comes apart without and studs etc snapping.
This man speaks the truth
Offline jamiep91
« Reply #20 on: December 15, 2013, 11:09:46 am »
I have pretty much everything fitted from audi s3's, r8's and rs4's so just need to swap the turbo
Offline jamiep91
« Reply #21 on: December 15, 2013, 11:09:58 am »
