Author Topic: Boost pressure logging in vcds?  (Read 5089 times)
Offline mk4gti-t
  • -Given: 61
« on: December 09, 2013, 12:32:11 pm »
Hi ive recently fitted a new south boost gauge which is reading upto a maximum of 9-10psi but im not sure how accurate that is. Is it possible to log boost levels using vcds to get a spot on reading? Also i am running a standard map i think but having had a major ecu failure and fitting a second hand unit it may not be, what are standard boost levels? Cheers  :happy2:
Offline GLIDN
Re: Boost pressure logging in vcds?
« Reply #1 on: December 10, 2013, 12:09:57 am »
here you go
http://www.goapr.co.uk/support/datalogging.php
All the info you might need to log. Is all in here.
Offline xjay1337
  • -Receive: 377
« Reply #2 on: December 10, 2013, 12:45:02 am »
Generally analogue pressure gauges are more accurate than electronic/digital ones. They are also faster to react as they are in real time.
I can tell you around 9psi is correct.
It may spike to around 12-13psi and hold around 8-10psi, dropping back to 5 or 6 psi near the redline.
Offline mk4gti-t
  • -Given: 61
« Reply #3 on: December 10, 2013, 01:06:50 am »
Nice one lads thanks for the info.
Donx22
« Reply #4 on: December 11, 2013, 12:14:57 pm »
is thisd k03/k04 standard or mapped? i asssume k03 standard?
Offline mk4gti-t
  • -Given: 61
« Reply #5 on: December 27, 2013, 08:48:07 pm »
Yea sorry for the late reply, K03 standard as far as i know as i fitted a 2nd hand ecu not too long ago after mine died  :surprised:
